Check the at the back of the printer where you plug in the power cable to see if its loose,and also check you power outlet from the wall,change another plug if possible to know what you dealing with.also make sure that the back cover where paper passes from onside is locked to home possition or else your printer will not turn on if its at unlock position,hope it helps
my samsung ml-1666 printer problem is while i'm push the power on button the printer LED (RED & Green) lite a second and goes off.what couse this problem.....
Hi there ok try 1. Turn off printer 2. Hold down Resume button and press Power button. 3. Keep holding down Power button and let Resume button go. 4. Press Resume button 2 times then let BOTH buttons go. 5. Green lights will flash and then stop blinking. 6. When green lights are solid, press the Resume button 4 times. 7. Press the Power button and the printer should turn off, if not, press the Power button once more. 8. Your printer should respond as normal
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Your waste ink tank is full. the following will get you going again, but the sponges should also be cleaned or replaced, although I have not heard of any one having problems without doing this.
Canon S900, S820, S750, S520
Turn off the printer.
Press and hold the RESUME button, then press and hold the POWER button.
While still holding the POWER button, Release the RESUME button, then press and release the RESUME button two more times in succession.
The printer mechanics will move momentarily. You are now in Service mode. Release the Power Button.
Pressing the RESUME key will select a function; for example, pressing RESUME 4 times will select the clear waste ink counter function. The lamp will alternate color with each key press.
1. Service/factory test printout, including ink sensor check 2. EEPROM info printout 3. EEPROM initialization 4. Clear the waste-ink counter 5. Printer model setting. (more selections beyond this- leave this alone)
After selecting mode, press the POWER button to commit the change, and return to the top of the function selection menu. Pressing the POWER button again turns off the printer for a restart.
Turn the printer off. Open the cover and check for any foreign objects that can cause your print head not to move. Check if you have put the ink cartridges correctly and make sure that the cover for the ink tray is closed. Turn the printer on, if your going to see the same status of the lights, it will be a hardware issue.
Contact Epson Technical Support.
United States Phone Number: (562)276-7525 Hours: Mon.- Fri. 6AM-8PM (PT) Sat. 7AM-4PM (PT)
first check put the power wires and then connection wires it may be short so that can happen and if that doesnt work open up your printer and check it out from the inside if some thing is not wrong with it, and do try it on other pc.
