Question about Kohler Generator 30 Kw Nat Gas Or Propane Indoor
What is the most likely cause of an Auxiliary Fault on a Kohler Generator (Model 30RZ62)?
Does anyone have a service manual for a Kohler 30RZ62 Generator with troubleshooting the fault codes?
  • Chuck Velez Oct 02, 2012
    I read from another post that it could be the low coolant level switch. So I disconnected the switch and started the generator manually. It ran for about 10 mins, and I reconnected the switch. The generator faulted out with an Auxiliary Fault. Therefore, I am going to purchase a new switch. I believe this is the issue.
  • Anonymous Mar 18, 2014
    how do i clear code 000-001 from kohler 125 generator?
  • 512 Answers
Problem solved by poster. good work!
Posted on Oct 08, 2012
3 Suggested Answers
6ya staff
SOURCE:
parlapanov
  • 142 Answers
SOURCE: Kohler 5E generator on my boat got wet there is no
  1. First you must clean it all, especialy the generator, windings, AVR etc. if it was wet with sea water (better do it with fresh water or electro-clean, than other liquids). Then you should dry it well (with a hot blower) for about, but not less than 24 hours, before starting.
  2. If you already started it wet, or it got wet while running, you may have some parts burned, with low insulation of cables, windings etc. Check the AVR, rings and brushes (if any) and other electronic boards for visualy burned elements or check the semiconductor elements (diodes and transistors) for proper qualities.
  3. You should check the gen. windings insulation resistence to hull (gen. iron) [all stator and rotor windings]. It should be more than 100 kOhm in order to let you start the generator motor.
  4. When dry and clean, with no burned elements you can start the engine. If it reaches its normal speed - measure the voltage on generator terminals, if it is OK check the connections (breakers, fuses) to the distribution panel. If it is very low under 30 V AC, the problem may be in AVR (Auto Voltage Reg. - Field DC supply)
  5. If the voltage is under 10 V AC, you may need to recharge the magnetic field with a 12 V battery connected shortly to field terminals - +/- respected.
If you fulfil these instructions and you need more help, please ask as an answer to this solution or on my e-mail: parlapanov@yahoo.com.
Please give some information about your generator: is it 5ECD, 5EKD or some other - then give some more details about it.
Posted on Jul 26, 2010
Anonymous
  • 3 Answers
SOURCE: I have a Kohler 12RESM1 propane generator with oc/uu code
I am getting the same exact problem and errors with my 12RES Kohler generator. It will try to start using a remote switch but fails. Then it will start using the switch at the generator. The error code it comes up with using the remote start switch is usually OF or UU. It is less than a year old. Can Kohler Help??? Dave R.
Posted on Feb 20, 2010
Have generator showing emergency stop code and will not start.
there are too emergency stop sensors on generators
one is over load
the other is low oil level in the sump (Low oil pressure)
That sensor is known to trigger and activate the emergency stop so check it out after you check the oil level in the sump
Feb 26, 2015 | Kohler 20resa 20kw Home Emergency Backup...
WHAT WOULD CAUSE A AUX FAULT ON A KOHLER GENERATOR MODEL 80ROZJ
Aux fault can be many things, if it failed to start you may get it. Try reseting and manually starting. See if it re-occurs while it is running or does it ever start and give error. I have seen this generator by a coolant level sending it is an auxillary fault
May 09, 2014 | Kohler Generator 30 Kw Nat Gas Or Propane...
WHAT IS THE MOST LIKELY CAUSE OF AN AUXILIARY FAULT ON A KOHLER GENERATOR MODEL 80ROZJ
Check radiator coolant fill right to the top, if it has a low level switch or faulty switch I have seen this
Downloading generator data direct to a PC
No there is no way to do that unless you are a Kohler dealer, and have their service software, which is only available to dealers. It is called KOloader.
Nov 23, 2013 | Kohler OnCue Generator Management System...
Generator code 0094 01
Can you be more specific? what model Kohler is it, Model number KW etc.
Sep 15, 2013 | Kohler Electrical Supplies
Kohler 30RZ62 generator Parts
You are going to have to register with Kohler and use this site to get your part:http://www.kohlerpower.com/residential/sectionfront.htm?sectionNumber=13561
Oct 02, 2012 | Kohler Electrical Supplies
Kohler Generator 30 Kw Nat Gas Or Propane Indoor Logo
5,240 people viewed this question
Top Kohler Electrical Supplies Experts
Sheldon Dedek
rjivaro
J. Bradshaw
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
