Question about Xerox Phaser 6250 Laser Printer
Xerox phaser 6250 is not printing black just a real light gray where should be black text. the toner is full and there aren't any error messages.
  • 1 more comment
  • baraki Feb 03, 2009
    Same problem. New toner cartridge and imaging unit. The black is coming in light. We had the toner provider come by to check, since we bought generic toner and thought that it might be the toner. His guess was that whatever mechanism is relaying the toner to the imaging unit isn't working.
  • Anonymous Feb 23, 2009
    fuser firmware failury
    an error was detecd inthe fuser firmware
    turn power off then on
    if error continues call service code 83
    fp fuser expired
    enqine nyram failure
    xerox phaser 6250 printer
    call me 9321426255 mahesh
    v urgent problem solution
  • Anonymous Mar 23, 2014
    I have error message "replace y toner." I tried to print in black and white only, would not allow this. This is for Xerox Phaser 6120.
  • 2 more comments
  • RanXer0x Oct 16, 2014
    URL is broken.
    Check the Printer Driver settings to be sure it's not set to replace black with grayscale. There are drivers out there that can override this and make grayscale black and vice versa.
    Troubleshoot: Print the configuration sheet from the printer. Then print a letter from the PC. If the printer configuration uses black for letters, and if the PC uses gray for the letter then it's a driver settings (or application setting) issue. You'll need to figure out which it is and reconfigure to use/allow black.
    Which application are you using to print? What type of document are you printing? Letter (alpha-numeric only)? Or presentation (multiple colors)?
SOURCE:
How to fix the waste toner cartridge error on a xerox 6505DN printer
Hi, check out the forums on this model, but you will be frustrated.
This is usually an error when a non-Xerox certified toner cartridge is used. If you can, try to get an original Xerox toner cartridge and see if the error clears. If you know someone else who has a working cartridge you can use that, to see if the issue clears.
https://forum.support.xerox.com/t5/Printing/Phaser-6500-quot-Waste-Full-Black-Cartridge-quot-error-message/td-p/22999
Oct 09, 2018 | Xerox Office Equipment & Supplies
My xerox phaser 6250 prints the first page fine then the black fades on the following pages
Your toner supply route is partially plugged and it can't keep up with the demand. It's not an easy process to clean it but a can of air, toner vac, and an area you don't mind getting dirty are necessary. Pull the imaging unit out and dig around, blowing and vacuuming out toner. Also, pull the black toner cartridge and work through that way as well. If your black toner is low, that might be the problem.
Jul 13, 2009 | Xerox Phaser 6250DP Laser Printer
Xerox Phaser 6125 Color Printer
I called Xerox and it seems that it's because the imaging unit is defective. They are seeding me one free of charge. Hope you can do the same...
Sep 20, 2008 | Xerox Phaser 6125 Laser Printer
Replace Transfer Roller
In the Phaser 6250 Color Laser Printer Service Manual (which I had to have emailed to me from my toner supplier since it is not available to the general public) I went to Chapter 6 - Error Messages and Codes. I had to reboot the printer. Here is the procedure.
Entering by rebooting the printer:
1. Turn the printer power OFF
2. Hold down the Back and Information buttons simutaneously and turn the printer
back on.
3. Continue to hold the buttons until the following message is displayed on the front
panel: Service Diagnostics V#.##, Initializing ....., and then release the buttons.
4. The front panel displays the Service Diagnostics Menu.
On the display is a menu. Find Transfer Roller. Press enter on this menu where it says Toner Waste (Not Full). Back out of the menu.
All of a sudden the machine came to life. You may have to turn off the printer and turn it back on again.
Good Luck
Jun 10, 2008 | Xerox Phaser 6250 Laser Printer
Phaser 6250 "Ram error" (?)
TRY FIRST (Solutions without parts):
For a continuous RAM Error message, try cleaning RAM contacts and reseating RAM.
NOTE: Third-party or generic RAM is not covered by warranty or service contract and should be removed for troubleshooting purposes.
TROUBLESHOOTING TIPS AND HINTS:
Replace RAM. If problem is not resolved, replace the Image Processor board. Please Note:
Intermittent 6250 RAM Errors can be resolved by replacing the Print Engine Board and EEPROM, remembering to Save/ Restore in Diagnostics.
Apr 15, 2008 | Xerox Phaser 6250DP Laser Printer
Phaser 6250 black toner is super light
http://office.support.xerox.com/SRVS/CGI-BIN/WEBCGI.cgi/,/?St=842,E=0000000000019251353,K=6024,Sxi=13,Case=obj(19377)
Click on Knowledge base from this site , then in the search box enter poor black quality. Look under black is faded or missing
Apr 08, 2008 | Xerox Phaser 6250N Printer
Xerox Phaser 6250 started printing bad
That really sounds like the imaging unit cleaner has an issue.
If you have one try the imaging unit, I really suspect that is your problem.
Black is Faded or Missing Step 1 Clean the Laser Windows and Remove Excess Toner From the Imaging Unit Step 2 Check or Replace the Imaging Unit Gear Retaining Pin Step 3 Replace the Imaging Unit (installation instructions) ic-film.gif
See if this link works. Xerox is infameous for these not working.
Apr 08, 2008 | Xerox Phaser 6250DP Laser Printer
Xerox phaser 6250 NVRAM Failure
Cycle power, try cleaning the CTD (ADC) sensor and toner full sensor. This is what Xerox has to say about the NVRAM failure: On the front panel, press the key labeled i to view information about the error. Record the error code number. Turn off the printer. Reseat the fuser. Reseat the imaging unit. Reseat the toner cartridges. Turn on the printer. If the error continues to be displayed contact service. To be on the safe side you can follow the instructions here on the procedure to replace the transfer roler: http://office.support.xerox.com/SRVS/cgi-bin/webcgi.cgi Good luck
Mar 25, 2006 | Xerox Phaser 6250DP Laser Printer
Xerox Phaser  6250 Laser Printer Logo
20,916 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
