Uniden 2.4 GHz Expandable Phone System with Digital Answering Machine Logo
Posted on Oct 02, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i change the rings before the answering machine answers on the power max 2.4?
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Uniden Master 102,366 Answers
  • Posted on Oct 02, 2012
Uniden Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10443507
Points
622693
Since you neglected to specify the model of your Uniden PowerMax 2.4GHz phone, I can only suggest you select it from the list beginning here to download a copy of the manual.
5 Related Answers
Anonymous
  • 2761 Answers
  • Posted on Mar 04, 2010
SOURCE: How to change the numbr or rings before...
1) With the phone in standby mode, press the menu/clock key three times.
You hear “Ring time” and the current ring time ([2 ], [ 4], [6 ], [T ] Toll
saver), and it is displayed on the main base. Then you hear the guidance for setting
the ring time.
2) Press the volume/select/ or up or down arrow key until the desired ring time appears.
3) Press the set key to select the new ring time. You hear a confirmation tone, then
the announcement “Ring time” followed by the new ring time. After a few
seconds, the system announces “To set record time, press menu again.”
Need the manual for your phone? You can download/print it here:
http://www.uniden.com/pdf/DXAI5588-2om.pdf
Bill B
KingDWS
Dave King
  • 1606 Answers
  • Posted on Mar 23, 2010
SOURCE: How do you change the number of rings before
Here is how to kill two birds with one stone.
http://www.uniden.com/products/productlisting.cfm?cat=Cordless%20Phones%20DECT%206.0http://www.uniden.com/products/productlisting.cfm?cat=Cordless%20Phones%20DECT%206.0
That is the page for Uniden DECT phones. www.uniden.com.
There are 6 pages to flip through and all you need to do is look at the picture for you phone. Click on it and it takes you to the phones page. On the upper right sid there is a link to download the owners manual in pdf form. Unfortunetly I can't tell your model from the information so I can't tell you the page or how to do it. Hopefully the manual will get you sorted out.
Anonymous
  • 64 Answers
  • Posted on Mar 06, 2009
SOURCE: how to extend rings on phone before answering machine starts
Hello, here is the link to the manual for that model:
http://www.uniden.com.au/resources_main/pdfs/XSA660.pdf
The information is on page 28
  • 102366 Answers
  • Posted on Jul 22, 2010
SOURCE: Just want a manual for a answering machine for
http://uniden.com/pdf/TRU4485om.pdf
Bruce Robin
  • 300 Answers
  • Posted on Aug 11, 2010
SOURCE: only two rings before answering machine I want
You can set the number of rings through the base unit's menu. See the manual for details. Lost it? Go to www.uniden.com and download one.
How do i extend the rings before the answer machine cuts in on my BT6500
Set the answer delay
1. Select Menu, Answer Phone is displayed, press
Select.
2. Press (Calls) until Settings is displayed, press Select.
3.Press (Calls) to highlight either Ans. & record or
Answer only and press Select.
4. Answer delay is displayed, use < or > to display
the number of rings you want (0-9 rings or Time
saver) and select Save. Saved will be displayed.
Set the maximum message length
You can set the maximum length that an answer
machine message can be: 1 minute, 2 minutes or 3
minutes. The default setting is 3 minutes.
Select.
3. Press (Calls) to highlight Ans. & record and press
Select.
4. Press (Calls) to display Max. msg length and then
press < or > to select the length you want and
Billy from Hayward
It is in the owners handbook page 45 get it while the link last
http://www.shop.bt.com/content/uni2/documentation/8h3h/bt6500_user_guide.pdf
I have a power max 2.4ghz the answer machine starts after only 1 ring
You need to change the settings on the answering machine the manual/instructions to do so can be found here: http://www.uniden.com/products/productdetail.cfm?product=TRU4465-2
I have an officejet 6500 all in one printer and I am setting up the fax section. It sends and recieve OK but my answering machine is picking up before the fax machine. How can I change that around so the...
You need to check the setup ..
The telephone line which is coming from out should be connected to the line 1 of the printer and Telephone answering machine should be connected to Line 2 .
2. You also need to check that after how many rings the Telephone answering machine answers the call you have to keep the "Rings to answer" 2 less than that of Telephone answering machine.
Lets assume that your Telephone Answering Machine answers the call after 4 rings then keep the rings to answer in All in One to 2
How to set Rings to Answer
1. Press the Setup button on the Front panel of the printer
2. Scroll Down and go to Basic Fax Setup - Select it
3. Scroll down and got to - Rings to Answer - Select it
4. Set the Rings here and then try Fax
it will fix the problem :)
How do you change the number of rings before machine turns on?
When the AT&T 1717 digital answering machine is powered off it will answer an incoming call after 10 rings, it will announce "machine is off" then beep twice, dial 0 to turn it on. The machine is now ready to answer calls. This 10 ring setting is factory set and cannot be modified. To set the number of rings to answer for normal operation press <SET UP> button and hold for 2 seconds, machine will announce current ring setting. Press and release <ANNC/SKIP> or <MEMO/REPEAT> until you hear the number of rings you want. Press and release <PLAY/STOP> to exit. The ring settings available are 2, 4, and toll saver. When set to toll saver machine will answer after 4 rings when there are no new messages and after two rings when is anew message. Here is a link where you can download manual, http://safemanuals.com/user-guide-instructions-owner-manual/AT%2526T/1717-_E
1helpful
Number of rings before recording answers
Choose how many times the line will
RINGS IS...” ring before the system answers a call.
• Set for 2 to 7 rings, or choose
Toll Saver 2/4 or Toll Saver 4/6.
• When set to Toll Saver 2/4, the system
answers after four rings when you have
when you do. Toll Saver 4/6 causes the
system to answer after six rings when
you have no new messages and after
four rings when you do.
• During setup, the Message Window will
display the number of rings (8 for Toll
Saver 2/4, or 9 for Toll Saver 4/6).
1helpful
Hangs up after 2 seconds into recording message
SETTING THE RINGS TO ANSWER
This setting allows you to select the number of rings before the answering system answers a call.
At idle status, hold down the volume "UP" button over two seconds to enter the ring times setting of answering. The answering system announces, "ring time two" (the default is 2).
To change the rings to answer, press and release the "PREVIOUS" button (<<) or the "NEXT" button (>>) and the answering system announces a number such as "2, 1, toll save, 9...” OR "2, 3, 4...", if you select the toll save and the digit LED light shows a “γ”, the answering system announces “toll save”.
After choosing a number, press the “PLAY/STOP” button one time to store the rings to answer, and the answering system confirms the setting and returns to the idle status.
NOTE: when the machine fails to operate properly, just unplug the power for 10 seconds, and redo the settings.
BT Synergy 3505
Hold down the forward skip button on the answer machine, it will say 3, if you have it set to 3 rings, just press the forward skip button again to the required number of rings, 10 being the max. Thats it job done.
1helpful
Number of rings
Looks like 6 is the Max, according to the Manual.
Setting the Ring Time
Ring Time allows you to set the number of rings the caller hears before your
answering system plays the outgoing message. You can set the ring time to answer
after two, four, or six rings. If you enable the Toll Saver (TS), the answering system
picks up after two rings if you have new messages and after four rings if there are
none.
1) Enter the Answ. Setup menu, and then the Ring Time
submenu (see "Entering the Menu Option" on
page 16).
2) Press volume up/down to select a Ring Time (Toll
Saver, 2 Times, 4 Times, or 6 Times).
3) Press the OK soft key. You will hear a confirmation tone.
Toll saver is a feature where you can call the phone yourself, if there are messages it wil answer in 2 rings, if not it'll answer in 4 rings. The idea is to hang up on the 3rd ring and save the LD changes.
Hope that fixed Ya...
Geno
2answers
Brother MFC8840D only 4 rings before fax pickup?
The TAD (TELPHONE ANSWERING DEVICE) must answer within four rings (the recommended setting is two rings). The MFC cannot hear CNG tones until the TAD has answered the call, and with four rings there are only 8 to 10 seconds of CNG tones left for the fax ?handshake?. message. do not recommend using the toll saver feature on your external answering machine if it exceeds five rings.
Top Uniden Lands Phones Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
