Brother HL4040CN Laser Printer Logo
Posted on Oct 02, 2012
ERROR C970 TOSHIBA E STUDIO 350 - Brother HL4040CN Laser Printer
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Oct 02, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1339
Points
7
[C970] High-voltage transformer abnormality
(1) Is the main charger installed securely?
(2) Check if the spring of high-voltage supply contact point is deformed.
(3) Check if the charger wire is broken or the main charger grid is deformed.
(4) Check if any foreign matters are on the charger wire or main charger grid.
(5) Is the transfer/separation charger installed securely?
(6) Check if the transfer/separation charger wire is broken or unhooked.
(7) Check if any foreign matter is on the transfer/separation charger wire.
Toshiba e studio 283 error c970
https://printcopy.info/?l=en&mod=erc&brand=Toshiba&model=e-Studio%20283&code=C970
C970
Description
Process related service call High-voltage transformer abnormality: Leakage of the main charger is detected.
Causes
Remedy
1. Is the main charger installed securely? 2. Check if the spring of high-voltage supply contact point is deformed. 3. Check if the needle electrode is broken or the main charger grid is deformed. 4. Check if any foreign matters is on the needle electrode or the main charger grid. 5. Check if the transfer roller and the separation needle are installed securely. 6. Check if the transfer roller or the separation needle is removed. 7. Check if there is any foreign matter attached on the transfer roller or the separation needle. Toshiba Studio 283 Error Codes
2helpful
Resetting error code c970 on toshiba e-studio
Karuna wire break
OR
its side charger problem clean it
OR
replace it
My problem toshiba e-s352 Code C970 and print is not ok please sole
C970 is an arc check your bios pin on maincharge as well as the transfer seperation unit its loosing powerto one of the charges
2answers
Hi, I have a Toshiba e-studio 2500c Color Copier. All of the sudden I've got a few errors. First a C390 then a CA00, but I was still able to make B&W copies, now I've got another error C970 and...
you seem to be having some issues ... ... ... the codes you are getting are related to the color calibration. possibly with the cyan developer unit or the high voltage board. to properly diagnose and fix the problem you will need a technican to fix the problem
1helpful
3answers
Error code C970 on my toshiba e-studio 2500c. Sais call for maintanance...Can I clear this or fix this on my own?
Check if the charger wire at the side door is broken or main charger grid is deformed.
& if any foreign matters are on the charger wire or main charger grid.
I have problem , My machine is toshiba 350 and proble is C970
it has a problem with the HIGH VOLTS CARD, maybe in the transfer area.
other posible solution it is that in the charge unit need to clean by humid.
2answers
How can i fix the error code C970 on my toshiba e-studio 230?
1. Check and clean the main charger, replace if required.
2. Check and clean the transfer/sep. unit, replace if required.
3. Before you replace the HVT board, check HVT connector bracket (the black color plastic piece mounted on the machine frame where the main charger connects). If this part is damaged or cracked, the high voltage will arc through this, which can cause C970. (found in several machines).
2helpful
I am getting white page when ever i try to print from my Toshiba e-studio 350. Installed drivers 3 times.
There are more solution
1. Primary or main chargers cable must be disconnect.
2. Tranfer charger ......
3. H.B.T. (High Voltage problem)
4. Transfer charger Connector is out of work, that means lickage, broken ...
Cheak this I think Thats the real problem, You can solve that by fixing the TR by any kind of glue, I think u can understand what u have to do so .....
100% confidental and this case You can see the error code C970.
Thanks
7helpful
2answers
Toshiba e studio 350 has a c970 code
C970 indicates charging issue. Need to check the T/S block and main charger for deform/broken wires.
12helpful
4answers
TOSHIBA E STUDIO 280 CALL FOR SERVICE
First of all check what is sub code with this .if it is not showing code press clear & 8 key at same time .code will bi shown .if no code just reset pm cycle count.MIAN AKHLAQ
Norman Weimar
Norman Weimar
k24674
