Electrolux Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher Logo
Posted on Dec 29, 2008
Frigidaire fridge door makes a loud popping sound
We have a side by side door frigidaire refrigerator that is less than 3 yrs old. The door, to the fridge only, makes a loud popping sound each time we open and close it. The freeezer door does not do this. The sound comes from the bottom hinge of the door. I needed some help on how I even begin to get this issue resolved.
  • 1 more comment
  • Anonymous Apr 17, 2009
    Same problem, since I bought it.
  • kenneth6140 Apr 20, 2009
    I have the same problem. I also took everything off the door to see if it had something to do with weight & nothing changed. It is a very annoying popping sound from the fridge side only!
  • tyecanuck May 15, 2009
    We have exactly the same problem - the fridge is now 6 years old and it is driving me nuts!
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 15, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
7271
Points
You need to take the door off the hinges and remove the lower hinge plate from the bottom of the door. This is where I found my popping problem. The black bushing with the 3 bumps and dips on it is loose in the plate going into the door. I took black eletrical tape and rapped it around the part that goes into the plate to tighten the bushing up so it wouldn't turn anymore. ( This was a temp fix to see if the popping would go away) 3 Weeks later and still working. If the sound comes back I will put some double sided sticky back foam on it. Both doors were doing this on my fridge, and now its as quite as a mouse. I hope this fix works for you.
Anonymous
Level 1:
New Friend:
  • Contributor 13 Answers
  • Posted on May 16, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
13
Questions
0
Helped
11549
Points
43
I had this similar problem with our side by side it is 3 yrs old.
1. Take off the offending door the bushing at the bottom is the problem. It is the black bumpy thing.
2. Unscrew the plate. Take it off clean off the bushing and place it back in the plate. Remember to put it back in the same way you took it out.
3. Take some gorilla gule. or similar strong adhesive. Apply VERY SMALL amount to bottom of bushing and around sides.
4. Replace to door, and put back on Frig.
FIXED
1helpful
Frigidaire Side by Side Refrigerator. How to stop the loud humming noise coming from it please?
Question edited for clarity.
It sounds like the compressor is struggling / overheating / failing. When was the last time your stripped the back out and removed all the fluff and debris? It overworks the compressor and gets red hot when the condenser coils get blocked. The struggling compressor causes the humming. Turn it off, keep the doors closed and vacuum it all out. Clean underneath and you might as well clean the floor and walls around it as the plan is to leave it disconnected for 1 to 2 hours to cool down and settle the refrigerant gas/liquid. Some other ideas below.
The evaporator fan motor circulates air over the coils to help keep things cool inside your fridge. If this motor starts to go bad, it will make a buzzing sound as it struggles to circulate air. You'll need to replace the evaporator fan motor to fix this problem.
Aug 22, 2022
Frigidaire Refrigerator Runs Loud? This May Be Why...
On my Frigidaire Gallery side by side refrigerator, my filter keeps popping out. When it is engaged, I get water but no ice.
replacement water filter keeps popping out of fridge - Shop ...
www.shopyourway.com > Manage My Life > Questions
Kenmore fridge water filter replacement #9911 looks a little different than the last one and pops out after a few minutes of installation ... How do I fix my Kenmore water filterthat keeps popping out? ... Side-by-Side Refrigerator - Stainless Steel.Missing: gallery
Frigidaire Pure Source 2 water filter keeps popping out. - Fixya
www.fixya.com/support/t2000027-frigidaire_pure_source_2_water_filter
... filter keeps popping out. I am posting this again because there were no responses to - Refrigerators question. ... I am trying to replace my water filter with a newFrigidaire Pure Source 2. I have a side by side Frigidaire. I removed the old ... When I press the water lever the Pure Source 2 filter pops out. I called Frigidaire and ...
2helpful
Frigidaire side by side freezer - LOUD noise...
It sounds like the evaporator fan is hitting ice that is built up on the evaporator coil. When it's making the noise, open the freezer door and see if it stops.
(Most models are wired so that the evaporator fan cuts off when the freezer door is open.)
Check the inside back, lower panel of the freezer for ice built up or frost on it. If there is, you have a defrost problem that is most likley a bad heater. It's located around the coil inside the freezer behind the panel you will be looking at. The defrost problem would explain the freezer not freezing ice cream.
Freezer cold- Fridge Not, Loud Noise
that is the damper door malfunctioning this open to allow cold air into the fridge compartment the damper needs to be replaced
A three loud consecutive popping sounds at various
You probably have a bad compressor. It's internal parts are held up with 4 springs and one of them has probably broken and causes the compressor piston to hit the side of the comp. housing. This will happen when the ref. shuts off. To be sure, if you turn the ref off at the controls then you should hear the noise in the back. If it is less than 5 years old you can get it replaced under warranty. if more than 5 years old it will just be noisy. it will most likely last several more years like it is. Let me know if I'm right.
1helpful
Freezer door not sealing well (Frigidaire side-by-side)
your house may be settling and now the refrigerator needs to be tiloted back slightly. take run the adjusters on the front in a little until the doo closes by it self.
Freezer door opens
its air pressure between the wo doors that cause it to open the freezer door.take some soapy water and clean the sels aroundboth doors to see itf thet dosent help use dish soap and a little water to clean the seals with it should stop it
2answers
there could be a partial restriction in the capiliary line causing higher that normal high side pressure in the system when the compressor is running
have the tech to replace the suction line along with the compressor let them know that this is the third one gone bad
Top Electrolux Dishwashers Experts
Mike Cairns
Mike Cairns
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
