Model # R-1410A
I m facing the same problem no other key work. Sharp microwave 8888 n all other Signs are flashing and I cannot remove Any sugection help plz.
Model # R-8R51
See this steps and fix it. God bless you
Reset the clock. Press "Clock" and the correct time, using
the number pads. Press "AM/PM" if applicable, and press "Start" or
"Clock" to confirm.
However if the problem persist the display board
main control board is faulty
SOURCE: Hi. our Sharp R242 Microwave
I saw an answer for this problem on a justanswer.com blog, and although it's for a slightly different model than yours, it's the exact same problem and they mention what to try to fix it:
http://www.justanswer.com/questions/2v2ff-my-microwave-flashes-8888-none-of-the-buttons-work-what
This was my initial thought...that the display isn't receiving information and going into the error code, which would be because of a loose ribbon connector, which carries the signals needed for operation. When you take it apart, be careful not to touch the high voltage capacitors- you can discharge them with a screwdriver blade by shorting them out, or cover them with electrical tape, temporarily.
Here's a web page that talks about how to check various microwave parts, and may be of help to identify the capacitor:
http://www.applianceaid.com/image/component1.JPG
Good luck, and hope this helps you get it fixed.
SOURCE: The touch pad is freeze, only shows 8888.
try gliding your fingers over the touch pad to see if any other buttons work , #8 is stuck, or shorted
SOURCE: Microwave Sharp carousel Model R3A36 keypad not working
Your keypad has failed.
It would need a new control panel frame, which comes with the keypad.
You simply remove the circuit board and plug it into the new frame.
It is part # FPNLCB070WRK0 and the best place to order Sharp parts is Tritronics.
SOURCE: Remove over the stove microwave Sharp R-1462
Ther are 2 long screws at the top on the left and right side in the cabinet.Remove them carefully it is heavy and will drop hard if you do not hold it while you remove them.If it does not come off then there maybe a release handle on the top left part of the vent you must look carfully hope that helped:)
SOURCE: Microwave display flashes
It may be bad electrolytic capacitors on the control board, but I would need your model number
We regularly repair such control
units for
customers nationwide by mail for $39.95 postpaid in about a
week or two with a one-year guarantee.
Feel free to contact me directly (and please remind me of your
full model number from the tag on the unit) for more
information & help.
We're
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
Hold down clock for 10 seconds. Start might work too
