Http://internethelp.centurylink.com/internethelp/modem-westell-7500-v14-07-wireless.html
You have to enable wireless in the router itself. Open this in browser and set up wireless 1. Open a web browser and go to http://192.168.1.1 or http://10.0.0.1. see url above for details
SOURCE: remote pc cannot access wireless
You can do a reset on your router. All computers must be must be getting its connection from your router. Your wired computer must be getting an ip address from the router(example is 192.168.1.x). You can then access the router page using your browser by typing the default gateway(example 192.168.x.1). This will take you to the router configuration page. You can set up the wireless network and your wireless network can now support more than 2 wireless computers.
SOURCE: Linksys wireless adapter and linksys wrt54g2 router not seeing each other
its possible that the wireless card does not have the correct wireless settings.
Open the linksys wireless monitor on your wife's laptop.
Go to the profiles tab, highlight the default SSID then click on edit at the bottom. It will search for the wireless network, from the list of networks that it will show you, click the name of your wireless network, in if the network is secured you will be ask to put in your network key. Then click connect. Then it will say that you profile was successfully configured. then click connect to network. It will take you back back to the screen where you saw no association to the access point, check if you will now get a new message. On that same screen click the more info button at the upper left hand side. Check the IP address it should be 192.168.1.x. If you have that IP then you can test if you will be albe to get online.
if you still have any problem just reply to this post.
SOURCE: Belkin router not giving signal to linksys adapter HELP!!!!!
I dont think belkin has a stable driver for win.7 at this time. I have a belkin n router with a belkin adapter and had no luck.
Some people have had some success using a Vista driver.
You could go to www.bioticaindia.com and download a win 7 driver there. They show a 48% success rate.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/robert_33deecd2f8e91168
SOURCE: Arris Model: TM602G S/N: TM02AH1G6 Modem is not
Hi ltuttle650,
If your modem is not communicating with your Linksys router, your Arris modem was most likely installed directly to a PC or Mac when either you or a technician installed it. As soon as it connected it registered your MAC address from your NIC. You need to make your sure that the modem is still talking to the PC or Mac. Please try the steps below.
1. Find out what your NIC's MAC is (go to "Start", "run", "CMD", "ipconfig/all")
2. Copy down your NIC's "Physical Address." That is the MAC.
3. Go into your router's web based utility (Linksys is 192.168.1.1, username:none ; pw: admin) and click on the "Advanced" tab.
4. Then click on the "MAC Address Clone" tab.
5. Type in the number that you copied down. Click "Apply."
6. Now power cycle your Modem while it is disconnected from your computer and router. Power Cycle the router. After everything has rebooted connect the router to the modem and you should be good to go!
In most cases, this should work, and you ought to have internet access now.
If this did not work, the following is a quick fix:
1. Go to the 'Applications & Gaming' tab
2. Click the sub-heading 'DMZ'
3. Click 'Enable'.
4. Click 'Save settings'.
5. Wait for the settings to save, and click 'Continue'.
If this doesn't work, I would recommend calling your cable ISP and telling them that you need a modem that will work with more than one computer, or you need them to send a tech out who is able to set up the internet through a router.
Hope it helps.
Thank you for using FixYa.
SOURCE: Trying to install new wireless adapter on guest
Press the reset button on the router, and hold that like about 20 seconds.
That will return all factory settings.
