Wodnering if I can lift the cooktop on this range for further cleaning if needed.
Hello friend, thanks for your inquiry!
From what you have described there is a popping noise within your Frigidaire oven when it is baking. It could be some food residue left on the element or an issue with the thermostat. I would recommend checking the inside of your oven for any food residue near or on your element that could cause a noise of any sort. I hope this information is helpful to some degree. -Matt
I appreciate your inquiry, Mark Waggoner!
From what you have described one igniter on your Frigidaire range will not start. It sounds like a possible issue with the burner or igniter. I was unable to locate any steps on how to disassemble your range. I did locate a parts manual which provides a through breakdown of all the parts within your range. If you continue to have issues I would suggest contacting a technician for proper disassembly of your range. I hope this information provided is helpful. -Matt
Frigidaire Manual Search Results
