Voyetra Turtle Beach Turtle Beach Montego II Home Studio Sound Card Logo
Anonymous Posted on Oct 02, 2012
No sound on dell dimension 4600 - Voyetra Turtle Beach Turtle Beach Montego II Home Studio Sound Card
  • 3 more comments
  • Anonymous Oct 02, 2012
    Can someone delete this please
  • Anonymous Oct 03, 2012
    My soundcard is an SB1040 not this one
  • Anonymous Oct 04, 2012
    Have checked with updates with no success Dell has told me there is no Win 7 driver for this soundcard
  • Anonymous Oct 29, 2012
    A new soundcard fixed the problem
  • Jason Madruga Mar 31, 2013
    I purchased a new sound card too but didn't need to as I just found out.
Jason Madruga
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Mar 31, 2013
Jason Madruga
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
22571
Points
Here are the drivers for Windows 7 (x32) for the Creative Labs SB0200 sound card.
https://docs.google.com/file/d/0BwZF4jEAVFSQNWdQRUhRa19aQ00/edit?usp=sharing
1) Extract the files from the link above
2) Go to Device Manager
3) Right click on the sound card with missing drivers and select update drivers
4) Find the drivers from the folder named "Creative SB Live! Series (WDM)"
5) As these were built for XP or 2000 you must ignore the warning messages.
6) TADAA!!
One problem is I can't find the driver for the MIDI port or whatever.
Not a problem as I don't need it and no other noticeable harm.
Be sure to set "Creative SB Live! Series (WDM)" as default playing and recording, and disable the other digital stuff.
Private Message me if you need help.
tags: Dell Dimension 4600, Windows XP, Windows 7
Anonymous
Level 3:
  • Master 2,878 Answers
  • Posted on Oct 04, 2012
Anonymous
Master
Level 3:
Answers
2878
Questions
0
Helped
488123
Points
8243
According to Microsoft, Sound Blaster 1040 fully compatible with Win 7 and does not need any extra software. Use Windows 7 Update and check for updates, under optional as well.
Dell Dimension 4600 audio
Hello download the driver here:
http://www.dell.com/support/drivers/us/en/04/Product/dimension-4600
The c model:
http://www.dell.com/support/drivers/us/en/04/Product/dimension-4600c
Here could be several versions of the driver so you just have to try.
Good luck
Need sound and vedeo driver for dell dimension 4600 motherboard
You can download the Drivers for Windows XP Operating System here:
http://support.dell.com/support/downloads/driverslist.aspx?os=WW1&catid=-1&dateid=-1&impid=-1&osl=EN&typeid=-1&formatid=-1&servicetag=&SystemID=DIM_P4_4600&hidos=NAA&hidlang=en&TabIndex=&scanSupported=False&scanConsent=False
1helpful
2answers
How do i open my Dell dimensions 4600 to install
Just lay it over on its right hand side, there a button on the top and the bottom, press these both at once and lift. It will just hinge up and give you plenty of access. When closing just make sure its lined up and it simply clicks back into place. Cheers from Scott
2answers
Soundcard for dell 4600
There are 4 different versions sound card drivers for this Dell Dimension model (4600).
Go to 4600 and select Audio then download which version from the list for your desktop.
Till next time, take care of your desktop.
1helpful
What kind of sound card do I need? I can't get any
The dimension 4600 has an integrated sound card, but if that is not working and a driver update does not correct the issue, then any sound card that used a PCI interface will work with that system.
1helpful
RAM for Dell Dimension 4600
Heres a link from DELL,it has all the correct parts and manuals for you,
This section is titled Removing and Installing Parts by DELL.
http://support.dell.com/support/edocs/systems/dim4600/en/4600/sm/parts.htm
Your memory is DDR Ram.
I have a Dell Dimension 4600, will a PCI Express sound card work in place of the original Sound Blaster 5.1 sound card
Well, the short answer to your question is "No, it won't work". The Dell Dimension 4600 does not have any PCI Express slots in it, therefore you can't install it, and therefore it won't work. But, if you installed a PCI sound card, it would work. The BIOS would recognize the add-on sound card, disable the onboard sound, and your sound will start going through the expansion card instead. Hope this helps.
Dell Dimension 4600 creative sound blaster card
It sounds like you may have broken your sound card. I had the same problem when I tried to digitise my old 4-track recordings.
I tried the broken card in another PC, found that it was not working, so I went out and bought a new sound card.
2answers
Seeking a diagram of what all the inputs on the rear of the 4600 are...duh
This Link below will take you to an online service manual for the Dell Dimension 4600. Click Here
Top Voyetra Turtle Beach Computers & Internet Experts
ADMIN Eric
ADMIN Eric
Greg Bjorn
Greg Bjorn
Mark Ultra
Are you a Voyetra Turtle Beach Computer and Internet Expert? Answer questions, earn points and help others
