I had 24VAC to the contact and unit running fine. Then I pulled 240vac disconnect to shut unit off to clean the condenser coils. Put disconnect back in and now no low voltage to contact ( 24Vac) and of course unit not running. Did I get a low voltage wire wet or something ???
very posisble.check the fuse on the board on the indor unit. replace with equal size fuse (not bigger probably 3 amp). if the indoor unit comes on then the fuse is fine and i would suspect the coil on the contactor has shorted
