SOURCE: hp laserjet 1320 problem
This is an error state that is not described at HP site.
Try to do a hard reset:
1) Turn off the printer
2) Press and hold down the green GO button
3) Turn the printer on and continue to hold the green GO button for at least 5 seconds, but not longer than 15 seconds. During the process, the Attention LED will turn on.
4) Release the GO button.NOTE: If both the Attention light and the Ready LEDs turn on before the GO button is released, the cold reset procedure must be started over at step 1.
5) The printer LEDs begin cycling. The cold reset process runs until completion and the printer returns to the Ready state.
Hope it will help you
SOURCE: blank display
If the printer control panel is blank when you turn on the printer, check the following items.
1 Make sure that the printer is plugged into an active electrical outlet receptacle that delivers the
correct voltage.
2 Make sure that the on/off switch is in the on position.
3 Make sure that the fan runs briefly, which indicates that the power supply is operational.
4 Make sure that the control-panel display wire-harness is connected. See the hint in the
procedure for Top cover.
5 Remove any HP Jetdirect or other EIO cards, and then try to turn the printer on again
SOURCE: the power light keeps blinking and the printer wont print
Here is the solution on Hp web site for Blinking light
Click Here
SOURCE: third light from the right keeps blinking printer
I had the same problem and the following worked for me: I used a cotton swab with alcohol to clean contact points (copper colored dots) on the back of the ink cartridges themselves. I also gently cleaned the brass-colored pins in the cartridge slots. Hope this solves your problem.
SOURCE: The printer light keeps on blinking continuously
goto control panel and click on printers or printer or faxes. when you open this folder your printer is shown double click on it and select all the previous print comands and if all comands will not removed switch off ur printer and the try again . and if the problem is same then unplug or plug ur usb data cable or if the problem can't be resolved the change ur data cable.
