Drove car night before...parked in garage, everything normal. went out next morning, wouldn't even click. tried the light switch and the side marker lamps and park lamps came on very dimly. battery posts are spotless and tight...i figured i must have left something on or a door ajar....tried jump starting with crummy cables....would just click, click, click even after a long time with the other car running at 1200 rpms...then trickle charged it overnight and only got the same, click, click,click.
SOURCE: I have a 1993 jaguar xj6 . It has a problem starting.
the steering wheel lock doesnt lock in till the steering wheel is turned a bit .as for the dash lights and wipers i would need to play with it to sort this one out ,because it could be anything froma earth wire to ??
SOURCE: 1993 Jaguar xj6 won't start, battery drained of
Is the car immobilized? if so you may have to lock and unlock the car with the key and not the remote.
Is it turning over or just nothing, also starter motor may be jammed. put the car in gear with the hand brake off and push the car forward until you feel the engine turn over. You dont need the keys in the car!
This should free the starter off, sometimes they jam very tight and will not move at all, on these jags. they get rusty quickly if sat about. I had a XJ many years ago great motors.
Good luck.
SOURCE: 1004 XJ6 Won't Start Suddenly - Security System? ECM?
try locking vehicle with remote then unlock it with remote,it might be the security needs to be reset.if that doesnt work look at the inertia switch
SOURCE: 2000 jaguar s-type. The problem is if parked
no it not possible. more like internal light or boot light left on.
