SOURCE: suggest config of DI 524
Are you using a DHCP server for boths sites A & B, or just using static IP addresses for all the PC's ? What is your IP scheme ? Are you using this D Liers just to connect sitenk routers just to connect sites A & B? Sorry for all these questions, I am trying to picture your network before attempting a solution for your needs.
SOURCE: WAN
WAN s not for your use now. dont dig with it bro..
tel me one thing.. what kind of connection you have? does the modem stores the password or you type the pass each time manually to connect to internet
SOURCE: Connecting a DI-524 to a DI-604
This shouldn't really be any problem simply use a short "Uplink" ethernet cable to join the routers thru the uplink port, or any port really, and that way ya should be able to wifi and access the net, set ya router that connects to the net for DCHP and disable that setting in the Wifi router and ya should be good to go?
SOURCE: My D 502T Adsl+2 will connect but when I try to
First of all, what IP address does the 502 give you when you plug into it alone? Do an IPCONFIG from DOS and note the numbers.
Now, what is the default IP of the 524. Is it the same as the 502?
If it is, change your 524's IP to something else, like 192.168.1.1.
If it isn't, please post back what your IP configuration is and what the link is, DSL,Cable Modem, PPPoE, or DHCP either fixed or variable.
Carl
Hi All,
I have a
are Logitech Model # A-00006 and the wireless antenna unit is
Model # A-00007.
Odd thing is I don't
hear it cutting out when I am making a direct call - only when it's a
multiparty Conf call.
Thank you inadvance,
B1L
Straight after I posted this, I was trying to fix it myself, So I right clicked on the little "Wireless network connection" icon, and clicked repair.
And viola, it's fixed.
Now it works fine, both computers. Except I suspect that the wireless is slower downloading speed than the normal one, I know lots of people have this problem but do you have any ideas how I can fix/help this?
Cheers mate, thanks for all the help and happy new year to you!
Ugh now it's barely working, sometimes it doesn't even detect my internet, and sometimes it does but it has a very low signal strength.
Btw, could you please explain how to do the things in your last comment?
try adding a range extender to your network. should cost about $45 at best buy. dont get the cheapest model but you also dont need the most expensive model either. try for something Cisco or linksys.
good luck
