GE JVM1540DN1BB microwawe
See this causes and fix it. God bless you
Touchpad and Control Panel
If the microwave buttons don't work the touchpad and control panel assembly are probably defective
Touchpad
touchpad might be at fault. Generally speaking, if the
display is working and some of the buttons respond correctly but some
don't, the problem is with the touchpad.
User Control and Display Board
If the microwave buttons don't work the main
control board is most likely defective and will need to be replaced.
Main Control Board
SOURCE: F3 Message and Beeping
On a GE/Hotpoint, F3 means you have a failed keypad.
If you or someone you know might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
It's at http://www.microwavedisplay.com/keypad_replacement.pdf
If you'd rather have us fix it for you, we do that for $39.95 plus parts and you can visit us via our link here on Fixya http://tinyurl.com/yzjozk
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
[email protected]
SOURCE: Turn off Beep on old Magic Chef microwave
On some older models, there is a sliding switch on the bottom edge of the control panel that turns it off. I've seen these on older Amanas, but not sure about others.
In newer models, they have some kind of help key which will get to to a menu which will turn it off.
Other models in between usually don't have that feature. In such cases, I as a technician have removed the beeper or taped over it to make it quieter, or even lifted one leg of a resistor attached to the beeper.
Someone less technical or less patient could just push the beeper sideways until it snaps off. No more beeps! *grin* And really, it is much weaker than the circuit board so it's a viable, if inelegant solution.
One other thing is to call Magic Chef with your model number:
http://www.mcappliance.com/contactus/contactus.asp
SOURCE: advantium oven F3
F3 means a shorted keypad. Is it possible that some spray cleaner got onto or into the controls?
I always recommend that instead users spray cleaner on a soft cloth then wipe the control panel.
Also, I always recommend non-ammonia cleaners since ammonia can crack and damage plastic.
Otherwise, the spray can get into the controls and lock it up or make it act odd.
If it does not dry out over time, it may need to be manually dried or blown out.
Othwrwise, the keypad may be damaged or worn out, or control unit may be damaged.
Some people replace them or have us do it.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
SOURCE: microwave beeping and says keypad short may need
the membrane gets dirt under them and shorts out the keypad,you may as well just replace the control board which includes the display and keypad on the same board
SOURCE: My GE microwave JVM1740DM1WW no
there is no easy fix to this units current problem it will need to be looked at by a service tech as the fault is an internal circuit shortout and needs to have the faulty circuit found and then replaced using expensive testing units
sorry
merry christmas
he most likely cause of this problem is a keypad on the control.
You can try the stop/clear keypad to silence the beeping.
You can put the controls into child lock and see if the intermittent beeping stops. The instructions to turn the child lock feature you have it in the owner manual . The child lock disables most keypads.
otherwise replace the control board.
God bless you
"Keypad Shorted"
ge jvm1540dn1bb unplug to reset touchpad
How do you get the keypad off
