Turned tv on standby light just flashing and unresponsive unplugged overnight still the same.
SOURCE: standby light flashes
the lamp thermal sensor is probably bad...you ma also have a lot of dust around the lamp fan..there is a service kit for this problem.
a1137954a..you must clean all the dust from the fan above the lamp or replace it.
SOURCE: Sony Flat screen tv troubles
My only advice is for you to get a service manual. The link I am inclosing has your manual for 10.99 and they provide unlimited free support. If you contact them and request that they email it to you, they will. Thats about your only recourse unless you have a tech come in cause of the complexity of your set. You will need a service manual. Heres the link.
http://servicemanuals.vstore.ca/
SOURCE: The standby/timer is flashing 6 times on my Sony KP-53HS30 TV
you must change ic reg.(ic mcz 3001db)
SOURCE: Samsung HLP4674W - changed bulb - still no picture - lights flash
If the lamp has been replaced I would think the Lamp ballast would be most likliest followed by the color wheel and then the Digital board. You can get any part needed for your model at www.tvrepairworld.com just leave them a email they respond quickly.
SOURCE: my sony sxrd projection tv wont turn on
From what I've been able to find, the problem is the fan that cools the bulb is not starting when you turn the tv on. Blow on it to get it going or clean with compressed air. The fan could be clogged up with lint etc. It's on the rear left of the tv.
