Mitsubishi WD-52525 52" Rear Projection HDTV Logo
Minnie Weaver Posted on Oct 01, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Mitsibushi need a ballast how much does it cost?
Mitsibushi needs a ballast, tv won't stay on
Anonymous
Level 3:
  • Mitsubishi Master 5,138 Answers
  • Posted on Oct 09, 2012
Anonymous
Mitsubishi Master
Level 3:
Answers
5138
Questions
5
Helped
1004430
Points
13534
Look on EBay, thats where I find better deals on ballast boards. You can also check on Shopjimmy.com
1helpful
How does a ballast for a hitachi ultravision dlp tv look
Anon, the bulb/lamp plugs into the ballast, The attached videos shows the ballast and location near the end of the video. Check the attached links. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
HITACHI how to replace your enclosure guide
Mitsubishi Toshiba Samsung DLP TV Bulb Won Turn On DIY Easy DLP Ballast...
hitachi ultravision dlp tv replacement ballast Google Search
1helpful
How to bypass ballast
The ballast is needed to start and regulate the bulb. I wouldnt recommend bypassing, unless you know how many volts the bulb needs to start(would need appropriate capasitor) and the watts/ amps needed to stay running (which would require a transformer) caps and transformers= a ballast, its easier to replace the ballast than build your own and risk it.
Toshiba TheaterWide 57HM167 Won't Turn On After Bulb Replacement
There is a ballast which drives the lamp--a hint would be to try to be in a position if possible to see if lamp ignites at all or even for a moment.
The ballasts do fail but rarely----it develops about 12,000 plus to the lamp and is much like spark plug wires as far as rf.
Some checks would have to be made and then the ballast priced--google the model number with ballast after it to get and idea.
No cut and dried solution here--several possible causes.
WD- 60738 Just replaced bulb Sept 9, 2011 Unit turns on green flashing timer light, No statis Light, no lamp light. I can hear audio but bulb does not come on. After a few minutes unit shutsdown. The buld...
Hi W Bloom,
First of all, thank you for contacting Fixya.com regarding your TV problem.
My first advice is to do system reset by pressing the "Power" button key at the front panel and hold it for 10 secs.
Please check also if you can access the "Error Code Log" by pressing the "Menu" "3" "5" "6" "4" in sequence before the unit gone to shutdown.
You've mentioned that the bulb has been replaced just last Sept and now it won't come on. The lamp can't be test using the multimeter but you can make a visual inspection to determine its condition. Most of the faulty lamp has an obvious burnt mark. There's a possibility that the symptoms is caused by busted lamp but in your case, if it is a genuine lamp replacement, then high chance that the fault is not the bulb.
You need to check the ballast board but not the high voltage output of it feeding the lamp. No voltage coming out from the power supply board to the ballast board can produced the same symptoms. You have to check the this voltage at connector CJ1, you must get 325V to 340V. Check also the lamp enable at connector CJ3(pin 4) you must get a low voltage upon turning on the set to confirmed that the mainboard giving a signal.
If there's no voltage at CJ1, then the fault is on the power supply board.
If the readings are normal, and still the ballast won't ignite (you can hear a slight snap sound when the ballast board trying to ignite), then you have to replaced it.
Click the link below to order online.
http://bigtvsale.blogge.rs/2011/05/31/discount-replacement-mitsubishi-oem-pwb-ballast-938p178010/
http://www.shopjimmy.com/mitsubishi-938p178010-lamp-ballast.htm
Please let me know if you need further assistance.
Good luck and take care!
Kind Regards,
Mjsazon
Replaced lamp, tv worked great for a week, yellow blinking status light, dust cover is secure and the switch is good. tv won't power up
Now the tv projection lamp tries to light up to the tv screen and shutting itself down,u hearing tv make alots of cliking noises to the tv set too?Yes,mean the Ballast board it is also dead,now must replaced the Ballast board too.The Ballast board only job are to ignite the tv projection lamp only.
Abs light stays on and goes off occassionally. What is the best way to get to the source of the problem?
I don't understand these questions
Any dash light you get is a Vehicle System
Malfunction ( no owners manual)
They have been with us for 30 years now,
still hundreds of questions a night
Study OBD2 Systems on the internet
All check lights need immediate attention
Check for Codes
Diagnose
Repair
Do so in a few days of any light on dash,they
won't go away & won't pass inspection & eventually
will end in costly repairs
Tv won't power on
Check power fuse first, cheapest fix, if no power light comes on at all. Ballast (ballast booster) next possibility, if power light stays red, but cost is about $400 P&L. Finally, the bulb, if power light comes on, stays green, but no picture. Get the manual for your specific model.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
