Unlock code requires
Hi, You can get the unlock code for a Samsung U600 from www.unlock-zone.com/samsung-sgh-u600/rs5wp9/ at affordable cost.
STEPS FOR UNLOCKING SAMSUNG U600
Method 1:
1 - Switch ON your Samsung SGH-U600 with a NOT ACCEPTED SIM Card.
2 - Samsung SGH-U600 will ask for "Password".
3 - Enter the Unlock Code.
OR (if the Samsung SGH-U600 shows "Insert Correct SIM Card")
Method 2:
2 - Don't bother about what's being displayed on your Samsung SGH-U600.
3 - Compose : #0111*CODE#.
SOURCE: please I need the unlocking code for samsung U600
Unlock Code
#7465625*638*7337#
Instruction to fallow
1. Take out the SIM card from the phone and switch the phone on.
2. Enter the unlock code into your handset.
3. Now replace your SIM card and turn the phone on.
4. Your handset should now be unlocked.
please rate
SOURCE: unlock samsung
Bring to a repair shop most of them unlock your phone for you. hope this helps...
SOURCE: have a samsung u600 on virgin cant unlock it
You have to purchase the code then you can get the instructions from http://www.mobileunlockguide.com/mobile-phone/16240/samsung-u600/ then unlock your mobile
SOURCE: my Samsung U600 keypad is locked .. next to the
first the keypad is automatically locked during a conversation.
to unlock the keypad push once on the power button at the top of the phone
SOURCE: i need to unlock my samsung u600 to any network
Hi Install the latest pc suite from samsung so you get the latest drivers and install. Rebbot. Do not conncet the phone until this is done. Reboot Download **** 1.03 by OTMAN-GSM copy/paste search and download for free. Insert a working sim. Power the phone , connect to PC , Open ****, hit START ,the programme should automaticly pick up what port the phones connected to. If not select it !!!!!!!!!!! DO NOT HIT UNLOCK OR READ CODES !!!!!!!. In the, PHONE RESET, select/ TICK "STACK RESETt" and push "SET" Wait until IT COMPLETES disconnect phone , pull out battery. Replace battery and insert the new sim. Power on and you phones unlocked. Works on the u600 and ultras Cheers Dandares
Method 1:Each Samsung U600 mobile phone has an unique unlock code. You can buy the unique unlock code for your Samsung U600 mobile phone using the form above.
1 - Switch ON your Samsung U600 with a NOT ACCEPTED SIM Card.
2 - Samsung U600 will ask for "Password".
OR (if the Samsung U600 shows "Insert Correct SIM Card")
Method 2:
2 - Don't bother about what's being displayed on your Samsung U600.
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Samsung U600 is locked to.
CODE: Its the unique Unlock Code for your Samsung U600.
If method 2 does not work, you can try method 2 again but this time without any SIM card on your Samsung U600.
