My 2 yr. old son pushed a key or combo of keys on my keyboard and it shrunk the font on that one page only. It's a page I frequent so it's very frustrating.
I've asked for help from the page tech. support team but they have no good answers.
I am sure I just need to push the same keys my son did, I just have no idea which ones!
Just press "Ctrl" key with "+" plus Key and both keys should be pressed simultaniously. You can also decreased the font by using "Ctrl" key with "-" minus key
If its an IE webpage , click View , the Text Size then Medium , which is the default setting.
On the particular page , ensure that the zoom setting in the lower right corner (Magnifying glass with a percentage next to it) is on 100% , if not , click the small arrow to the right on it and click 100%
hope this solves your problem
Try CTRL +
And please give this solution a fixya rating. Thanks!
1. If computer is on, turn it off by choosing Shut Down from the Apple menu.
2. Connect power adapter to computer and to a working power source.
3. On built-in keyboard, press (left-side) Shift-Control-Option along with power button just once. Important: Use Shift-Control-Option keys on left side of keyboard.
Note: When the LED on the MagSafe connector is orange/amber, resetting the SMC will change it to green for a few seconds, indicating that SMC was correctly reset.
4. Wait 5 seconds and press power button to start computer.
If it starts without beeping errors reset the PRAM (Parameter RAM)
p.p1 {margin: 0.0px 0.0px 0.0px 0.0px; font: 10.0px Helvetica; color: #1a1a18} span.Apple-tab-span {white-space:pre}
1. If computer is on, turn it off by choosing Shut Down from Apple menu.
2. Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously in Step
4. Note: If keyboard does not have an Option key, use Alt key instead.
3. Press power button.
4. Immediately press and hold Command-Option-P-R keys.
Important: You must press this key combination before the gray screen appears.
5. Hold down keys until computer restarts, and you hear startup chime a second time.
6. Release keys.
p.p1 {margin: 0.0px 0.0px 0.0px 0.0px; font: 12.0px Helvetica; color: #1a1a18}
