Mp610 will copy in color, but outputs a blank page if black copy button used.
SOURCE: Canon iP90 only prints blank pages
Remove the printer from control panel, under installed printers, then unplug the usb cable and reinstall the printer drivers using printer cd, or download from canon support website.
SOURCE: Cannon S200Spx prints blank pages
The problem is likely to come from your printer settings in your printer properties dialog box. Right-click the printer icon and select Properties. You will see within the dialog where to set the printer to print on black only and then appropriate. restart your pc and then try sending to printer again. Good luck
SOURCE: copies are blank pages and doesn't indicate toner problem.
Bad lasrer shutter. There is a redesigned one going in warranty claim machines. the shutter can be removed but it breaks safty laws.
SOURCE: Printing in black and white on Canon MP610
Mollmal...if you read the previous posts you would realize that the grayscale option still uses color....and does not solve the problem...there are two black ink cartridges in my printer...a small one that goes with all the color ones and a large black ink resevoir...the small one is completely empty...the big one is full....I think what people want to know is ....how do they print in black and white solely from the big one...I would like to know also
SOURCE: my canon mp620 won't print the black color.
I had the same problem, after replacing both black cartridges. I solved the issue by running the print head cleaner. Below is the link to the instructions.
For Mac:http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=17406
For PC: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=17406
