Question about Water Heaters
After plumber flushed out my gas water heater the valve where he connected flush hose leaks. 1st only a few drops, but now a dinner plate size puddle. It never leaked before this. I had the flush done
It is from 2004 new. I live alone so its not like a whole family is using it constantly. Also I had that corrosion rod replaced in it 2 years ago since we have kinda hard water here.
  • Water Heaters Master
  • 5,353 Answers
Put a brass garden hose cap over the dripping drain valve.
Call the plumber.
Absolutely the plumber should take care of this for you since the cap has to be tightened pretty tight.
See illustration:
http://waterheatertimer.org/images/drain-with-cap-500.jpg
http://waterheatertimer.org/How-to-replace-water-heater-drain-valve.html
Comment back and let me know what happens.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on Oct 01, 2012
SOURCE:
  • 686 Answers
SOURCE: Relief valve constantly releasing water.
lower your thermostats a bit. If your temperature is set to the hottest setting, then chances are no relief valve will do
Posted on Jan 08, 2009
  • 297 Answers
SOURCE: Sulphur smell
you can remove it but this will not fix your problem, you must cut the cold side pour in about half gallon of bleach ,drain heater of a gallon and a half first, then pour in bleach wait one hour then use as normal. you will have a bleach smell for some time but this will make the egg smell disapate.try this it worked for me.
Posted on Jul 21, 2009
vincob
  • 718 Answers
SOURCE: My gas water heater (Rheem) is making noise, like
Stop wondering, replace the thing and your troubles will be over. Your troubles are inside the tank and not worth even giving it another thought. Go for it!
Posted on Oct 15, 2009
  • 35 Answers
SOURCE: my reliance 606 water heater drain valve is
You are going to have to drain it anyway. So drain it and take the old one with you to get a new one. In case you don't know turn the breaker off before you drain it. If you don.t you will melt the heating elements. They get too hot out of water.
Posted on Jan 06, 2010
  • 50 Answers
SOURCE: I have a GG40T06/487-246 GE SmartWater Water
A 10 year old water heater is at the end of its life expectancy. No sense replacing a gas valve to have the tank rust out next month. I'ld replace the whole unit. Also, install a drip pan, under it and a WAGS safety device. Any water in the pan and the WAGS will shut off he Water and Gas. If your water heater has an expansion tank near by, replace that too.
Posted on Jul 19, 2010
WOULD SOFT WATER HAVE A BAD EFFECT ON THIS MODEL AS IT HAS RUSTY BITS
Hot water heaters are a collector of sediment. The proper care includes flushing out the collected debris through the low side drain faucet. The problem is the faucet is not designed correctly to carry out the needed task. If you are handy... turn off the water and gas or electricity to your water heater. Relieve the water pressure through the temperature/pressure relief valve on the side of the water heater tank. Once pressure is relieved close the valve. Determine if you have a 1/2 inch or a 3/4 inch diameter drain valve hole in the side of the tank where the drain valve is located. The drain valve can be removed with channel lock pliers, an 8 or 10 inch adjustable wrench, or a small 8 to 10 inch pipe wrench. Water will leak out the threaded hole while the valve is out. If everything is closed maybe 2 cups of water will leak out of the hot water tank as you check drain valve thread size. DO NOT take your time checking thread size. After you know the pipe thread size go to the hardware store ( Home Depot, Lowe's etc) purchase a short nipple (1 1/2 to 3 inch depending on available space) and a ball valve (brass) due to the water temperature. You will also need a brass adapter for pipe thread to garden hose thread (male both ends). This adapter goes into the ball valve to allow for the connection of a garden hose. Connect the pipe and valve together using the correct pipe thread sealant and install in place of the original plastic drain valve. Install pipe to hose adapter using thread sealant. With the ball valve in place turn the water back on. Gas or electricity back on. Connect a garden hose to the ball valve. Place the other end of the garden hose in a safe area as hot water and debris will be expelled through the hose. With water on, Gas or Electricity on and the relief valve closed actuate the ball valve to the full open position for approximately 3 seconds then close the valve. Repeat the open and close of the ball valve three times. Observe the debris that emptied out of the garden hose. You may be surprised at what you see. If the water runs clear, disconnect the garden hose the task is completed. You can wait until the following year to repeat the process. Your pipe and valve are now a part of the water heater, they may remain in place. Put the hose away.
Aug 31, 2015 | Water Water Heaters
I need to flush my Atwood L/P Gas water heater MPD 93756 I'm unable to locate where you add the vinegar. Can you advise!
Remove hot pipe connection, and flush out through drain valve.
Or remove TP valve and flush out through drain valve.
Connect small circulating pump to 5 gallon bucket with 2 gallons white vinegar like they do with tankless water heater, as shown following Bosch manual. And let run for 45 minutes.
http://waterheatertimer.org/pdf/Bosch_Descaling-heat-exchanger.pdf
White vinegar is safe for humans.
If odor is the problem, use H2O2 hydrogen peroxide, and not bleach. Hydrogen peroxide is safe for humans and easy to flush out of water heater and pipes. While it can take weeks to get rid of bleach, which is caustic and toxic.
Oct 26, 2012 | RTO Atwood DSI-RV Water Heater-6 Gallon
Rust in water heater tank
the tank needs flushed out ! heres how. Water heater manufacturers recommend flushing sediment from your storage type water heater periodically.
If your water heater is gas, set the gas valve to "Pilot" to prevent the burners from coming on while you are flushing it. If your heater is electric be sure to turn off the circuit breakers. With an electric water heater, if the water level drops below the heating elements and the thermostat turns the elements on, the heating elements will probably burn out quite rapidly. Connect a garden hose to the drain valve at the bottom of the tank, Close the shut off valve on the cold inlet to the water heater. open the temperature/pressure relief valve at the top of the tank by lifting the lever. Leave the valve open. Open the drain valve at the bottom of the heater allowing the water to flow out through the garden hose. when the water is clear your finished. close pressure relief valve on top of tank and turn water back on.
Open a hot water faucet in your house, and let it run until no air bubbles come out.
Turn the heater back on, and with gas units re-light the pilot light if necessary. good-day !
Apr 24, 2012 | Water Heaters
I have a leak coming from the "cold" line right at the valve joint. There is signifigant calcuim build up on the pipe from the valve to the connection of the water heater, (maybe 8 inch of pipe)...
Very simple - call a Plumber. He will fix your plumbing problem, and any foreseen potential problems related to your water leak. He may also suggest replacing your 6 year old water heater. Of course ..... for a professional cost.
However, depending on your time, skills, proper tools, patience and luck, it's easy enough to perform yourself:
1. Switch off the water heater Breakers (220v) in your service panel.
2. Turn off the water supply to the water heater.
3. Attach a water hose to the drain faucet. ( a good time to flush sediment -calcium deposits)
4. Open a hot water faucet to vent (above the level of the water heater drain - kitchen sink)
5. Remove the suspected leak components. (a union connection is a good place to start)
6. Install New pipes -3 wrap all male threaded ends with teflon Tap. Tighten securely - using 2 wrenches.
NOTE: Before refilling - you can turn on the water heater supply valve for a few minutes, to flush out any lingering calcium debris.
7. Shut off drain valve - remove hose. Shut off venting hot water faucet.
8. Turn on water supply valve to fill water heater.
9. Open a hot water faucet to relieve air pressure while filling - preferably the bath tub faucet, it doesn't have a screen that might clog.
10. When water flows without air - shut off tub faucet.
11. Look for leaks.
12. Switch the water heater Breakers on.
Note: 50 gallons should take an hour or more to heat up. Turn on a hot water valve momentarily within this heat up time to relieve thermal expansion. ( the PT valve on your water heater will perform this task if pressures/temperature exceed new water heater tolerances - it's just a precaution to introduce these fluctuating pressures on your fragile 6 year old unit)
These are just basic instructions - assuming you fill in the common sense and work safe steps.
Good Luck - The Skill will only come after trying.
Mar 05, 2011 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
It occasionally leaks water - maybe a quart, leaves a puddle in the middle of the floor and I can see that it came somewhere from the heater, but not where because it is not leaking from anyplace. I have...
Here are a few tings to look for:
When COLD WATER comes into the heater, it might cause sweating of the Cold water line, if the humidity is high in the house? This is usually in summer time only-- when the humidity inside the house is higher..
Another possible place, is the relief valve:
If you have a check valve or two in the system, that ends up trapping all the COLD water in the tank, as it goes thru its heating cycle, -- the Cold water expands, and has to be relieved-- Thus the relief valve will spit out a puddle of water keeping the pressure at a safe level.
(However-- usually the system has a drop pipe coming out of the relief valve-- so likely you would have said that the puddle was at the bottom of the drop pipe-- and you probably would have suspected it..)
However-- Do these suggestions give you some ideas of where the water puddle is coming from ?
Tell us more-
Mack B
Jan 17, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Rheem hot water heater problem
If by the hot water over flow valve you are refering to the T&P valve. It is activated by high temp. or high pressure. It is possible that when you flushed the lines it caused this to open. It is also common for these once open to get a little debris in them and cause them to continue to leak. Sometimes you can open and close them a few times and get them to reseal. Other times you have to replace them. Hope this helps.
May 07, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Rinnai tankless water heater
LC is the error code that you get when you have limescale buildup in the heat exchanger. You need to flush your heat exchanger. If you have the manual for your water heater, use it. The manual to mine is attached. The procedure for flushing it is covered on page 12. I suggest that you have a certified Rinnai plumber perform this task as it requires a ciruclating pump and some hoses that you need to connect to your water heater. If you don't perform this task, it is possible that you will need to replace your heat exchanger and this is not something covered by Rinnai's warranty.
Sep 21, 2009 | Rinnai Webstone The isolator EXP tankless...
Code LC, I cleaned the filter, won't stop beeping
you need to flush out the rinnai. to do this you will need 4 gallons of white viniger & a circulating pump. #1 disconnect the power. #2 close both incoming & outgoing water valves under the unit. #3 conect a drain hose to the out going flush valve ( flush valves are under the unit & have brass caps) #4 connect pump outlet hose to ingoing flush valve. #5 put pump incoming hose & drain hose from outgoing flush valve in a 5 gallon bucket. #6 pour 4 gallons of vinager into the bucket. #7 open both flush valves. #8 turn on the circulating pump & let viniger pump in the incoming flush valve through the rinnai & out the outgoing flush valve back into the bucket for 45 min. #9 disconct pump from incoming side & close incoming flush valve.( don,t close outgoing vaves at this time) #10 put out going hose in empty bucket. #11 open incoming water to flush viniger out of unit. # 12 disconct outgoing hose , close outgoing flush valve & open outgoing water valve. #13 clean filter & turn on power.
Jul 08, 2009 | Rinnai Water Heaters
My gas bill is so high what settings should the temp on the water and ch be set at ?
The temperature setting should not make that big of a difference. Have you checked for gas lines for leaks? You can do this by using a dishwasher soap and water mix, spray it on all the pipes and if there is a leak it will blow bubbles. Do you have a drippy faucet on the hot side? Do you have gas heating for your house?
If it is an older heater, you may want to flush out the sediment from the heater by attaching a hose to the valve at the bottom, open the valve and let the water run down a drain for a few minutes.
That said, set it at a temperature below scalding.
Mar 03, 2009 | Water Heaters
Water Heaters Logo
Top Water Heaters Experts
Donni Steen
Paul Carew
Are you a Water Heater Expert? Answer questions, earn points and help others
