open the remote c. and clean for oxide, dirty, corrosion, and bad contacts, clean with c.cleaner. change the batteries with the same type ALKALINE. 3) clean the contacts batteries with c.cleaner. and try again. If the problem persist you must go to the repair shop Tv for FIX IT. The Syscom circuit and associates can be faulty.
There are 5 different codes for Magnavox.
0054, 0706, 0030, 1454, 1254.
If you need instructions, here they are. Press and releaseTV. Press and hold SET until the LED blinks twice. (the first blink doesn't count. wait a few seconds) Release the SET button, and enter one of the 4 digit code. The LED should blink twice again. Aim the remote at your TV and press POWER. Keep trying until you find the right code.
first, press the channel -/+ button on the TV. If that doesn't turn on the TV, then it means you have to replace the bulb of your TV. The bulb is most likely dead.
It sounds like you would like to re-assign one of the function buttons on the remote to control a different device. If you would like to program the CBL/SAT button to control a DVD player, here are the steps:
On the remote, press and hold SET until the LED blinks twice, then release SET.
Enter 9 9 2. The LED will blink twice.
Press DVD/VCR once.
Press CBL/SAT once. The LED will blink twice. The CBL/SAT key is now ready to be set up to control your DVD player.
To setup the CBL/SAT button to control your Magnavox DVD player, follow these steps:
Turn on your DVD.
On the remote, press the CBL key once.
Press and hold SET until the LED blinks twice, then release SET.
Enter the first four-digit code from the following list: 0503, 0675. The LED will blink twice. If it does not blink twice, go back to step 2 and try the same code again.
Aim the remote at the DVD and press POWER. The device should turn off. If it does not turn off, repeat steps 2 through 5 with the next code in the list.
