ASUS K8N-E Deluxe Motherboard Logo
Anonymous Posted on Jan 30, 2018
Windows keeps asking for driver for SCSI/raid host controller
Hi Guys on start up windows xp 64bit it keeps saying it found new hardware and needs drivers for SCSI/Raid Hostcontroller. I tried to use the bios CD, but on install it says something went wrong. Anyone know a way how to overcome this stuff? As far as I know I dont use this Raid host controller.
Jure Meh
Level 1:
  • Contributor 49 Answers
  • Posted on Jan 30, 2018
Jure Meh
Contributor
Level 1:
Answers
49
Questions
Helped
5524
Points
99
Try another version of windows. Some dont have drivers u need to perform setup.
  • Jure Meh
    Jure Meh Jan 30, 2018
Vebble
Level 3:
Master:
  • ASUS Master 395 Answers
Vebble
ASUS Master
Level 3:
Master:
Answers
395
Questions
0
Helped
108871
Points
1210
Visit the motherboard manufacturers website for the drivers you need. Even if you don't use the RAID function the hardware is still built on the motherboard and you will need the drivers for windows to communicate with the hardware correctly. You might also find the drivers on the "Driver" CD that came with the motherboard.
1 Related Answer
Anonymous
  • 2878 Answers
  • Posted on Oct 01, 2012
SOURCE: windows keeps asking for driver for SCSI/raid host controller
Cancel and disable in Device Manager. If not in BIOS.
How to installed xp2 in server hp proliant ml 350 my hard drive ok
You may need raid controller driver for HP proliant ml 350. Copy raid controller driver in flopy disc, insert it in flopy drive, insert cd in cd driver, boot server from cd and start installation process, as soon as you see Press F6 if you need to install third party scsi drivers or raid controller, press F6 and follow the instruction. It will then ask you to select RAID driver file and then will continue to windows xp installation.
Regards,
Kaushik Patel
tip
How-to repair Windows XP, How to Perform an In-Place Upgrade
One of the best kept secrets of Windows XP is it's built in repair feature!
In previous versions of Windows, correcting an operating system error, or installing a new motherboard, usually meant formating and reinstalling, resulting in loss of all data. Don't worry; Windows XP repair feature won't delete your data, installed programs, personal information, or settings. It just repairs the operating system!
Why would I want to reinstall Windows XP?
1) Can't start Windows XP in safe mode.
2) You have problems caused by a recently installed system update (Windows Update, hotfix, Windows XP service pack, or Microsoft Internet Explorer update).
3) Your problems can't be solved with system restore, or you can't access system restore.
4) You've installed a new motherboard, or made other major hardware changes and need to reinstall Windows.
Let's get started!
Step 1: Rule out hardware issues. Windows Repair will only fix software problems. Hardware issues can also cause boot problems (i.e. bad hard drive, memory, CPU, or power supply).
Step 2: Backup. It's always a good idea to backup your important data before making changes to Windows XP. Relax, if you follow these instructions your data will be perfectly safe.
Step 3: Boot from your Windows XP CD. Insert the Windows XP CD into your computer's CD-ROM or DVD-ROM drive, and then restart your computer. When the "Press any key to boot from CD" message appears on the screen, press a key to start your computer from the Windows XP CD. Can't boot from your CD? Please see the note at the bottom of this page (Configuring Your Computer to Boot from CD).
Step 4: A blue screen will appear and begin loading Windows XP Setup from the CD.
Note: RAID/SCSI/Unsupported UDMA users:
You will be prompted to "press F6 to install any third party SCSI or RAID drivers". Most users will not have to press F6, but if you are running RAID, SCSI or unsupported UDMA controllers, then you will have to have your controller drivers on a floppy disk. If you are unsure whether you have RAID/SCSI, then simply let the CD load without pressing F6.
When completed loading files, you will be presented with the following "Windows Setup" screen, and your first option. Select "To set up Windows XP now, press ENTER". DO NOT select Recovery Console.
Note: The system repair function will remove any updates you have previously installed that are not included on the CD. Drivers will also be reverted to their original XP versions, as well as some settings (network & performance settings may sometimes be reset to their defaults). It may be necessary to reactivate your Windows XP as well. When finished, you will have to download all of the updates from Microsoft Windows Update, because they are all replaced during repair.
Let's get started!
When presented with the screen below. press the F8 key to continue
Next, Windows Setup will find existing Windows XP installations. You will be asked to repair an existing XP installation, or install a fresh copy of Windows XP.
If no installations are found, then you will not be given the option to repair. This may happen if the data or partition on your drive is too corrupted.
Note: If you install a fresh copy, all data on that partition will be lost!
Your almost finished! Windows XP will appear to be installing itself for the first time, but it will retain all of your data and settings. Just follow the prompts, and have your CD-KEY ready if needed.
Do you have more than one system, or lost your CD-KEY? Visit the keyfinder page to retrieve your CD-KEY.
Update: Due to the proliferation of the Blaster and Welchia Worm/Virus be aware that a Repair Install will leave your system vulnerable. You can get infected within seconds. Do not go on line until you have enabled XP's firewall first.
Remember to run Windows Update! (install critical updates first)
Many computers are not configured to boot from the CDROM. If you cannot boot from the CDROM, this is probably due to the boot order of your devices being incorrect. You can change this in the BIOS.
You enter the BIOS from the first screen you see when you turn your computer on. To enter your BIOS, most users here will press the DEL key.
Most Dell, Toshiba, Gateway, Sony & HP systems will press F2.
Compaq users will usually have to press F10.
IBM typically uses F1 or F2.
Other brands may have different keys to press to enter setup, F1, F2, Del, Tab and CTRL+S. If possible see the manual for your computer or motherboard. Also, the BIOS will usually display which button to press to "enter setup" during POST (if it flashes by too fast, press the Pause key).
When you enter the BIOS setup, you need to change the boot order. The CDROM should be setup before the Hard Drive. Each BIOS is different, but here is an example:
on Jun 18, 2010 • Computers & Internet
1helpful
Scsi/raid host controller
redux1
its old
hp.com has no driver page. now.
end of life for that and XP for 3 years now.
so....
join the HP.forum
then ask for the correct SATA driver
post your PCI codes.
click CP
click DM
click your bad, SATA chip driver.
below is NIC, example, only
then post them on hp link in my 2nd post;
3helpful
I can't installation windows xp. any solution?
Step 1 - Start your PC and place your Windows XP CD in your CD/DVD-ROM drive. Your PC should automatically detect the CD and you will get a message saying "Press any key to boot from CD". Soon as computer starts booting from the CD your will get the following screen:
Step 2 - At this stage it will ask you to press F6 if you want to install a third party Raid or SCSI driver. If you are using a an IDE Hard Drive then you do not need to press F6. If you are using a SCSI or SATA Hard drive then you must press F6 otherwise Windows will not detect your Hard Drive during the installation. Please make sure you have the Raid drivers on a floppy disk. Normally the drivers are supplied on a CD which you can copy to a floppy disk ready to be installed. If you are not sure how to do this then please read your motherboard manuals for more information.
Step 3 - Press S to Specify that you want to install additional device.
Step 4 - You will be asked to insert the floppy disk with the Raid or SCSI drivers. Press enter after you have inserted the disk.
Step 5 - You will see a list of Raid drivers for your HDD. Select the correct driver for your device and press enter.
Step 6 - You will then get a Windows XP Professional Setup screen. You have the option to do a new Windows install, Repair previous install or quit. Since we are doing a new install we just press Enter to continue.
2helpful
2answers
SCSI/RAID Host Controller/Driver cannot be found
Windows cannot find the correct drivers for this device. So, let's research a little bit.
Are you using SATA or RAID on the computer? If not, there is nothing that needs fixing.
If you are, then reinstall the RAID software from your motherboard installation disk, which should repair this issue.
If you do not have the driver installation disk from your motherboard, for whatever reason, go to their website. Almost every motherboard manufacturer provides easy access to drivers.
good luck
tony
Pci ide controller for third hard disk
You need to enter into scsi bios first, then do an autodetect for hard drive, this will set the IDE/SCSI hard drive on raid controller.
To enter SCSI control you need to press the same key stated on screen on startup (F6 I assume) I think F3 is just boot settings.
If the card do not enter regularly in CMOS settings for the raid then this card is defective.
2helpful
Updat to new sata hard drive from old idie hard drive.wont reconi
Hi, you will need to load the sata raid drivers when installing the OS. Some off the older versions of xp will not have these, when windows is installing it will ask if you need to install a 3rd party raid driver press F6. later on it will ask you to insert the raid driver disk. which you may have to do/make yourself if you haven't already got one.
Raid 0 on Intellistation 6221?
That particular work station comes with both IDE and SCSI drive interface controllers. The IDE drive should be used for your OS. The SCSI drives for your data storage. Now, the issue is to get the SCSI to work in RAID_0 as I understand.
You iwll need a RAID controller such as Adaptec AHA-3940AU WD SCSI Host Controller, which may be found on eBay (used) for a very affordable price. The driver software may be downloaded directly from Adaptec, so I suggest you do that in the iterim peroid, and store drivers on a USB thumb drive.
Hope this helps you.
Unable to find Mass Storage Controller Driver
Hi koolkeef, your KT7A-RAID uses the KT133A chipset. You can find drivers for that chipset located at VIA's web site.
http://www.viaarena.com/default.aspx?PageID=2&OSID=1
Happy hunting & good luck!
Mike
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
