Bought new.I have a very old liquid gas stove works that great. I wanted a new one. I should have tried it out, but had faith in Coleman name. I can't adjust temp on either burner. Tried different brands of propane. Burned just about everything except water on our trip. I think its the regulator??
SOURCE: burner lights and then goes out almost immediately
http://www.coleman.com/coleman/images/pdf/2300-700.pdf
Trouble shooting guide
SOURCE: Flames shooting up from back of Coleman stove.
Buy a new one. do not attempt to use this one again. There could be a pin hole in the propane lines or just a small crack. If you can hear it then there's a problem.
However if you really want to fix this one try putting water on the propane lines and then putting on a new tank and opening the valve. DO NOT LIGHT THE STOVE. where there are bubbles there is your leak. When you find it seal it with a Flame retardent sealent or clamp the line. Also I believe Lowe's sells parts that may work. just find out which line is leaking and replace the whole line.
I highly recommend just buying a new one and destroying the old one. DO NOT just throw it away please. Some one out there will grab it and try and use it. They will find out the hard way and maybe get hurt badly themselves or hurt someone else. Just imagine the guy who grabs it and goes camping with his family. Him and his son start it up. the son is right next to the unit. The guy fires it up and boom the son gets burned. Is it just me or would you feel bad if you knew this guy. I have seen it first hand. trust me it sucks. A buddy of mine did this and his son was in hospital for 3 days. he said he will never do that again.
So for safety sake please just buy the new one. don't take unnessecary risks if you don't have too.
SOURCE: how to operate a coleman two burner stove using
If you are talking about the old type that runs on Coleman fuel, start by putting some oil in the hole beside the pump knob to make sure that the gasket is lubricated. Fill with fuel and pump it up, keeping your thumb over the hole in the end of the pump knob. When you have pumped up enough pressure, turn on and light the main burner, then secondary burner if necessary.
SOURCE: Coleman 425 2-burner white gas stove pops out flame on low heat
There is water in your fuel. Drain the tank and flush it out with denatured alcohol. Refill with fresh fuel.
SOURCE: coleman hot water on demand
Does anyone have a AC charger for the Hot Water Heater on Demand? I would be willing to buy one.
Thanks,
llhancock
