Sony Playstation 3 (PS3) Console Logo
Posted on Sep 30, 2012
My ps3 will not play a disc & does not show a disc
I was playing a game, the game suddenly froze and i could not retreive it.i took it out &tried another game with no success. the disc also ,does not show up on the screen.
Anonymous
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Sep 30, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
346
Points
8
Have you checked to see if your ps3 has taken any damage?
3 Related Answers
Anonymous
  • 344 Answers
  • Posted on Jul 26, 2008
SOURCE: ps3 not spinning disk
Hello.
When you put in a disc, listen for the disc to start spinning. If you do not hear that then the laser and/or the spindle have blown out. You will have to get your Blu-Ray player serviced by a pro or Sony. Sony may fix it for free. They know that the drives are failing. So call them first. Otherwise the laser assembly needs to be replaced in the BR drive.
I hope this helps! Good luck to you.
Anonymous
  • 64 Answers
  • Posted on May 12, 2009
SOURCE: My ps3 won't play ps3 games anymore.
I had the same issue. I had to send it to PSR Repairs to have it checked out. They ended up replacing the hard drive & the laser lens. According to them, both those components contributed to the freezing up & inability to turn back on. Before I sent it in, I was able to get it to turn back on by holding down both the power button & eject button simultainiously. Lie it beep once, then double beep... Once you hear the double beep, release both buttons. A menu will come up giving you 6 options. Try option 3 first! you wont lose any saved items with this option. If that doesn't work, you will need to use option 6. This will delete ALL of your saved items, but there's a chance that you may not have to have your console repaired. You can retrieve trophies, games & demos from the PlayStation Store. Good luck! If I can be of further help, comment me back under this heading!
Anonymous
  • 46 Answers
  • Posted on Jun 25, 2009
SOURCE: My PS3 won't play an disc games, the disc icon doesn't even show
Sadly there currently is no fix for this problem. I've also had this same problem and contacted Sony about it.
You need to send it in to them to get it serviced. You can do this at:
www.us.playstation.com/Support/PS3
or
uk.playstation.com/help-support/ps3
If your warrenty has expired it will cost around $180.
Hope This Helps. Also be sure to rate whether it did or not.
I was playing fallout 3 when it froze-i ejected disc and now my ps3 doesnt load any discs i try-the disc icon doesnt apear at all!
Mate this exact thing happened to my mate playing the same game.
He called Sony and they took it away and fixed it...
Get on to them.
I was playing a game and all of a sudden the ps3 froze up
that is just glitch that almost any game or any game console will do occassionally but rarely its nothing to worry about unless it does it more than once in the same spot then it is probably the game disc is scratched or the game itself has a glitch there
Playstation 3 froze on game now wont play any games
unplug everything, clean the discs, plug in and try again
1helpful
2answers
Since i got assassins creed my ps3 was freezing a lot
Oh dear, i'm afraid to say you've got one of the 'fatal' error codes. The error you're encountering means there is a major problem with the blu-ray drive (you're PS3 is pretty much shot)...sad.gif
The only thing you can do is ring Sony's tech support and arrange for a replacement console. If you are still under their one year warranty, you will get a replacement console free of charge
or if your console still works just dont play that game
if it keeps freezeing its becuse of the blu-ray driver :( you would need to try setting it to factory def's or if that does'nt work try rolling back the firmware upgrades........or just buy a xbox 360..
Ps3 will not play discs
You will need the laser replaced.
My PS3 is not reading any of my games
Try another game see if it loads, im assuming it stopped playing the game, froze, or gave some sort of error right?
Ps3 can't read the games..PLZ HELP
my ps3 it wont read games i buy it 7 months ago can you pls help me thank you very much
PS3 will not eject the disc nor acknowledge the game being in the console
NEVER EVER TURN YOUR SYSTEM OF WHEN YOU ARE PLAYING ONLINE AND THE GAME FREEZES!!!...
Just try to wait for 30 - 50 sec.
If that does not work than EJECT THE DISC AND THAN TURN OF THE SYSTEM, It has nothing to do with your PS3, Check your connection status and reset all your internet settings BUT NOT THE SYSTEM ITSELF.
If this still doesnt work than there's something wrong with the disc.
Ps3 suddenly won't play games anymore
Sounds like a faulty/dirty/bad laser. Call sony 1-800-345-SONY (7669)
ask them what they can do! Normally its at least 168$ charge to get your ps3 back in order unless you are willing to open it up yourself.. if so let me know I can help you find parts and help you fix it.. parts are not to expensive but in the long run it may be better to either sell it as broke or send it in!
I do buy broken ps3's and can get you a deal on used or new systems!
1helpful
2answers
My PS3 Games wont show up in the games list
Return under warranty.
the blu ray laser will have been slightly overheated and as a result will need to be replaced.
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
