I sant type any message or call using my phone
SOURCE: sony ericsson t280i
You will have to call your voicemail number (network specific) and delete voicemails from there, not from your phone.
SOURCE: unlock sony ericsson w580i
Ok, THIS WILL WORK! It worked on my W580i and it wasn't even supposed
to. FIRST! Download (8.8MB) XS++ From
HERE:http://forums.se-nse.net/index.php?showtopic=16338
SECOND! No install. It just runs.
Make
sure you have ALL drivers for YOUR phone. That should be under the
bettery. Under model... or something like that. HERE!
http://www.nodevice.com/driver/company/Sony_Ericsson.html
Take
your phone, turn it off. Start this program and click on connect.
You'll have 30 seconds to plug your phone into your computer and HOLD C
The entire time! (the delete button or 2). If connected, then click at
the button: GDFS. There will be a phone lock reset to "0000". Click it.
It will take no more than 45 seconds. I promise. Unplug your phone, and
vuala! If your phone won't turn on, try pulling out the battery,
putting it back and trying again. This program is also good for
flashing phones, and putting flash menues on your phone. Also unlocking
it and debranding it. GOOD LUCK!
SOURCE: sony ericsson Z310i blank screen
This just happened to me, the solution is to wiggle the top half a bit (like you wanna break it, but don't break it.) The root of the problem is a loose wire that connects the two phone parts. Mine still goes blank on me but then i wiggle it... just a little bit...
SOURCE: Themes not supported in Sony Ericsson F305
This phone does not support any downloadable themes because this phone doesnt have themes option, only wallpapers are downloadable. It supports jpg format. If it has a theme folder, everything would be easy. Just download from sites like http://www.zedge.net/themes/ and set it as theme. But unfortunately, you can't download themes for this phone.
