See this causes and fix it. God bless you
Lid Switch Assembly
If the washer stops mid cycle the lid switch
assembly might be defective. This is a very common problem. The lid
switch assembly can fail either mechanically or electrically. Test any
electrical switches with an Ohm meter for continuity. The switches
should have continuity according to their design.
Door Lock Motor and Switch Assembly
If the washer stops mid cycle the door lock
assembly should be checked. The door lock can fail either mechanically
or electrically. Test any switches on the door lock with an Ohm meter.
The switches should have continuity according to their design.
Water Inlet Valve
If the washer stops mid cycle the water inlet
valve cold water side may have failed. Most washers have a cold water
rinse and so if they can't fill with cold water they just sit
indefinitely waiting for the cold water to enter. If there is cold water
to the water inlet valve and the cold water works in other parts of the
cycle - or to make warm water - the valve is not the problem.
Main Control Board
If the washer stops mid-cycle the main
control board might be defective. This is not common. Check other causes
first such as the lid or door switch and other components.
Timer
If the washer stops mid cycle the timer might
be defective. This part is often misdiagnosed, check other components
before replacing this timer.
see the diagram attached.
SOURCE: I NEED HELP WITH MY WASHING MACHINE
Remove the pump from the machine and check if you have any clogged there. Check as well that the connected pipes to the pump are clean from any clogged. Good luck !
SOURCE: LG wft7014pp wont drain rinse nor spin
do you have a drip-dry function...as this cancels the spin cycle unless you select it yourself
SOURCE: Hotpoint Aqualtis LCD display language
Follow this link and read where to find your model # and insert it in the box. I hope this helps. http://genet.geappliances.com/DocSearch/Dispatcher?REQUEST=SEARCHWITHURLCONNECTION
SOURCE: hotpoint aqualtis aqxxd169 washing machine
The m/c will not normally spin if there is a lot of water in it.
You need to check the pump to see if it is working o/k, and check the filter also.
The filter is located behind the bottom kick strip at the front.
Undo screws ,remove strip and unscrew the pump cover anti- clockwiwse to remove, be care ful as there will be some water run out.Clean filter and try again.
Plz rate my solution.
Thanks.
Also in the first instance check the drain pump filter for any blockage or, if there isn't a drain pump filter fitted the pump will need to be removed and inspected for any blockages. If you have any further questions message me back. Please also remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future Thanks Rick
