Samsung SWA-4000 Logo
Posted on Sep 30, 2012
Cooling fan makes a noise
Fan makes noise
Loose fan belt
It can be worn out fan belt or the fan is got dried up and needs lubrication.Inspect fan belt.
Check the help link mentioned below:----
Engine makes noise and Cooling Fan belt Breaks?
http://howtobyme.blogspot.com/2011/12/engine-makes-noise-and-cooling-fan-belt.html
Hp proliant dl 180 g5 cooling fan issues fan given noise
I would power the server off. Blow it out with a can of air. Power it back up.. If it is still making a noise, you need to replace the fan.
My computer fan making loud noise ,why?
fans tend to make loud noise right before they stop working!!! check to make sure that there is no clump of dust inside affecting the spin of the blades
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/charles_c2f37a3461344482
1helpful
Air conditioner fan is making a loud noise
1. Could be a caught foreign object between A/C (air conditioning) fan and cooling radiator, producing this loud noise.
2. Could be a damaged fan blade, mowing the cooling radiator.
3. Could be a loud noise comming from the fan's electrical motor.
4. Could be a broken off fin (small wing) of the cooling radiator, striking the A/C fan, producing this loud noise.
2answers
My fans are very loud do I need to replace them
check the plastic rings behind the fan blades, check to make sure plastic rings is tight and the screws holding fan cage on. Then when putting the fan cage back together, make sure it is tight so it wont vibrate
1helpful
Over heat cooling fan load noise remove and replace
A bearing more than likely has went bad causing your fan to stop properly cooling your unit. Replace with a compatible fan and you should be all set. Hope this helps.
2helpful
2answers
My CPU is making lot of noise especially when I'm using programs like Adobe reader
The CPU wont make noise unless its frying. So its either your hard drives, cd drives, or your fans.
If its your fans i sugest buying newer "Cool Master" fans that are powerful but less noisy
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
