The 2000 Chevy Impala 3.4 liter engine rocker arm bolt torque specification is 45 pounds. The rocker arm bolts should be torqued in 15 pound intervals.
The rocker arms need to be adjusted, they are not set to a specific torque, they use self locking "crimp" nuts to hold the adjustment, these nuts should not be used over to hold the adjustment replace them.. With the lifters fully "pumped" up tighten the rocker arms to "zero" lash, the turn them in an additional 3/4 turn, you are done.
www.gbodyolds.com/forum/showthread.php?754-Oldsmobile-Torque... Feb 7, 2013 - 2 posts - 2 authors
Oldsmobile Small-Block Engines Cylinder Head Bolts (1/2in. bolt) 130 ft. lbs. Cylinder Head ... Rocker Arm Pivot Bolt 25 ft. lbs. Rod Bearing ...
AutoZoneGM Cutlass RWD 1970-1987 Repair Guide ... To remove the rocker arms from the shaft, the nylon arm retainers must be removed. ... 7: Engine valve system, 260, 307, 350, 403 Oldsmobile built engines ... Unfasten the two bolts that attach the rocker arm pivot to the cylinder head. ... Torque the retaining bolts to 25 ft. lbs.
you dont torque rocker arms, they are hydralic they are adjusted by running the engine at idle with valve cover off back off the rocker nut till you hear them clicking, then tighten them till clicking stops, then 1/4 turn more, each one is done separately, you need to use some sort of shield to keep the oil from pumping out all over every thing because it can get a bit messy
99 chevy malibu v6 3.1 engine, head bolt torque is-- 98 through 2001 is step1- 37 foot lbs, step 2- rotate an additional 90 degrees (1/4 turn). the rocker arm bolts are 168-in. lbs.
