Kodak Esp 5210 Inkjet All-in-one Multifunction Printer Copier Scanner Wifi "a" Logo
A
Anonymous Posted on Sep 29, 2012
My printer ESP5210 is showing error codes 3501,3606,3507. What can i do to fix this
When printing a test page its all blurred, and its displaying error codes 06.Error code 3501 07.Error code 3606 08.Error code 3508 09.Error code 3507 10.Error code 3507
John Smith
Level 2:
Habit-Forming:
New Friend:
  • Kodak Expert 35 Answers
  • Posted on Mar 28, 2018
John Smith
Kodak Expert
Level 2:
Habit-Forming:
New Friend:
Answers
35
Questions
0
Helped
278308
Points
265
Hi, call Printer Experts to solve your issue for free. Toll Free Phone Number - 877-690-9305
david willimes
Level 2:
Sergeant:
  • Expert 260 Answers
  • Posted on Sep 28, 2015
david willimes
Expert
Level 2:
Sergeant:
Answers
260
Questions
0
Helped
121009
Points
563
To resolve this error, close the printer access door. The printer will not operate while the door/cover is open.
If the error continues even after you close the printer access door, power cycle the printer:
  1. Turn off the power (press the On/Off button on the printer).
  2. Unplug the printer power cord from the back of the printer.
  3. Wait approximately 30 seconds.
  4. Plug the printer power cord into the back of the printer.
  5. Turn on the power to the printer.
for more help visit https://cbrtechsolutions.net
4 Related Answers
Anonymous
  • 295 Answers
  • Posted on Sep 21, 2009
SOURCE: black ink is faded
Open the kodak all in one home center on your desktop and click on [?] on top most right hand side. choose maintenance under general links and choose printhead cleaning. if this does not solve the issue, call kodak @ 1800 421 6699 and they will replace the printhead for you free of cost.
Anonymous
  • 262 Answers
  • Posted on Nov 08, 2009
SOURCE: Scanner motor move failed error code 6202
6202 error code means that the scanner motor failed
to solve this
-Open the printer access door of your printer
-Unplug power cable
-then after 30secs plug the power able back
-If the printer is already power-up the message printer access door will appear
-Close th printer access door
-try to scan or print
If this issue not solve call tech support of kodak Toll free 1 800 421 6699
Anonymous
  • Posted on Jan 16, 2010
SOURCE: printer error code 6202 when I start my printer
I unplugged the power supply several times. So far it seems to be working.
Anonymous
  • Posted on Jun 22, 2012
SOURCE: printer working but page is blank after printing
try this select all in the page that you want to print then press ctrl +p it will show you a window in the bottom of that window press print selection it most work
4answers
My printer is showing this Epson Printer Error Code 0xe5?
Reasons behind Epson Error Code 0xe5:-
If malware strikes your PC, then it can decrease down your PC speed and display this error. CR encoder crash or motor driver crash is the other important reason for Epson error code 0xe5.
Step to Fix Epson Printer Error Code 0XE5:-
1:-Scan your Computer- You need to scan your computer for malware. Step
2:-Reset the Printer- check whether your computer can recognize a wireless printer, establish the connection. Step
3:-Inspect the Printer-Check the printhead and replace it if it is in bad condition. Step
4:-Check the Cartridges- Open the lid of the cartridges to check the level of ink.
If the Error does not resolve To Fix Epson Printer Error Code 0xe5, you want to join with Printer Error Support specialists. You can also follow the easy steps to Epson Printer Error Code 0XE5 are given below in the BLOG link.
Reset code No error display but all print out is
Check the toner/drum cartridge. reboot the printer. This could've a high voltage power supply issue.
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_7148ad2a373711a3
Printer Photosmart 8450. Using HP black cartridge. Received message saying the printer did not recognize the cartridge because it was not HP. Removed it and tried several times to print. Gave up and...
Regarding your HP94 black ink cartridge error problem and inability to print to your HP PS 8450 printer, this type of problem is probably an internal micro-electronic failure inside the HP94 ink cartridge.
To determine which cartridge is causing the issue and/or to confirm an electrical problem with one of the ink cartridges (or possibly both), perform both the Internal Self-Test page along with the Pen Electrical tests (diagnostics) to evaluate the electrical condition of both ink cartridges....
Please first verify the age of the ink cartridge(s)....look at imprinted date on front (or back) of ink cartridge. If this 'warranty expiration date' has expired, then potential cartridge failures can occur due to internal corrosion, etc.
A. Ensure BOTH carriage/flex cables and BOTH ink cartridge contacts are thoroughly clean before proceeding: http://inkjet411.com/?page_id=1519
B. Print Self-Test Page:
1. Press CANCEL and SAVE simultaneously (SAVE is the left-most button before POWER on/off.)
2. Using left/right arrow keys, navigate to 'pen electrical test'.
3. Select Enter to print test - evaluate nozzle test pattern.
-- If the printer prints the self test page then this demonstrates the printer is generally functional and that the problem is likely with one of the ink cartridges. Please note this is a 'forced' service test...the printer will attempt to print the test page whether the cartridges are good or bad. If the Self-Test page can be successfully printed but regular/normal printing cannot, then one of the ink cartridges is likely internally damaged. Remove and replace suspect cartridge to confirm.
C. Perform Cartridge Diagnostics tests using either C.1 or C.2 procedure below (varies by printer model):
C.1. Tap 41/43 Diagnostics Test:
1. To enter the Manufacturing Tests menu, press the 3 small, round buttons on the front panel simultaneously for >5secs: 'OK', 'CANCEL', & 'SELECT PHOTOS' (or 'Print Photos')
2. Using left/right arrow keys, navigate to Special Reports (or System Menu). Select Enter.
3. Navigate to 'print-mech button tap' menu.
4. Select Ok ('code = 0' will be displayed); click and hold Right Arrow until 'code = 41' (or attempt 'code = 43' if nothing prints using '41') is displayed.
5. Select Ok. Within one minute the Tap 41 (or 43) diagnostic test pattern should be initiated and print. Refer to video to help evaluate test pattern. Refer to 2nd video for guidance on how to read the diagnostic test pattern: http://inkjet411.com/?page_id=1741
NOTE 1: A good HP 93/95/97/99 color cartridge should display 600 good nozzles, while a good HP 92/94/96/98 black ink cartridge should show 672 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. For reference only, refer to the following HP Deskjet video which shows how to read the HP 93-97 ink cartridge diagnostic test print: http://inkjet411.com/?page_id=1741 (see 2nd video)
C.2. Pen Electrical / Error Bypass Procedure:
2. Using left/right arrow keys, navigate to Reports Menu (or System Menu). Select 'pen electrical test'.
3. Select Level 1, 2, or 3. Enter to print test - evaluate nozzle electrical test print.
NOTE 2: Pen recovery level 1, 2 or 3 clears cartridge errors, unblocking the printer to permit you to print the TEST PAGE with the normal MENU / TOOLS /PRINT TEST PAGE choice to aid in printer evaluation.
NOTE 3: Cartridge Error Bypass Message (Emergency Printing only): The Pen Recovery Level 1 clears cartridge errors and permits you to print the TEST PAGE with the normal MENU / TOOLS / PRINT TEST PAGE choice.
For additional information on North American ink refill services at a major retailer near you (should you wish to save ~50% on ink costs), general printing problem resolutions or advanced HP printer diagnosis procedures (error bypass/printer reset methods, etc.), please visit Inkjet411:
http://www.inkjet411.com
My Lexmark 4650 keeps telling me that my margins need adjusting, plus it is giving me blurred copies.
Check Page Preview before printing your file and see if the application you are using recognizes the entire page and does not cut-off the edges.
You can try to print Fit to Page or Borderless and see if that helps.
For your blurred copies, Please follow the steps below to fix your problem:
  1. From the printer operator panel, press the Setup button.
  2. Go to Maintenance.
  3. Select Align Cartridges. Your printer will then print a page to align your cartridges.
  4. After the test page is printed, try to print a document again to verify that the problem is fixed.
Should you still need assistance, please leave a comment to my response and I'll get back to you. Should this resolves your problem, your rating will be greatly appreciated.
What does error code 006-370 mean?
http://support.dell.com/support/edocs/systems/5100cn/en/UG/section18.html
see this page for detail, i hope this helpfull, if you think this helpfull please rate very helpfull or helpfull. thanks for using fixya
4helpful
3answers
Describe your Ricoh Aficio 1232C Error Code SC481 Problem
Defective main motor
• Image transfer belt out of position
• Belt mark blurred or absent
Right from the service manual
My best guess is belt mark blurred or missing
or image belt out of position
1helpful
3answers
Screen showing the message "remove and check right cartridge". Have done this several times and still can't print
I've had the same error:
Hold down the following keys:
Photosmart Express, Photo Fix, Reprints, Print Photos and then Help.
You'll get the message: "Enter Special Key Combo"
Press OK.
Scroll over to Reports then self test: and press ok, it should print. a selftest report.
If you get an error Pen in Chute 1, or 2, has tsr failure: Call/Chat with an HP technician.
Printing crooked, blurred, bad roller?
Sounds like when you pulled out the paper jam, you misaligned the print carriage. That would produce both the noises you hear and the print quality issues. HP.com has a few web pages on their site that might help. The first one deals with noisy print carriages. Unfortunately, it's not dedicated to just your product, but the steps should generally apply:
Resolving Noisy Print Carriage Issues
There's a separate web page available for troubleshooting crooked or skewed printouts:
Printed Text or images are Crooked or Skewed
If all else fails, unplug the power cord from the printer, wait 20 seconds or so, then plug it back in. That should restart the printer and make it go into a self test which may include a realignment procedure. Watch for any error messages on the display on the printer's control panel. Sometimes to realign, it prints out two test pages and instructs you to place the first printout on the scanner bed and then press Enter.
Go to the following web page and when it opens, scroll down to the section "Replacing the print cartridges", and find step 9 in that section for alignment instructions.
Replacing Print Cartridges
Good luck.
7answers
Printer Error Code 20 HP Deskjet
Dear rowanleigh,
What u have to do is just unistall the printer Driver restart the system then Reinstall the printer driver. and also do one thing delet all the temp files, temporary internet files & run the Disk cleanup tool.
Regards,
Bittu_8
Top Kodak Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
