LG WM2487H Front Load Washer Logo
Jimmie L Hatcher Posted on Sep 29, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
MY LG FRNOT LOAD LEAKS WASHING INTO WASHING DRUM WHEN NOT IN USE. WHATS THE PROBLEM
Wateer leaks into the when not in use
Anonymous
Level 2:
Sergeant:
  • Expert 389 Answers
  • Posted on Oct 02, 2012
Anonymous
Expert
Level 2:
Sergeant:
Answers
389
Questions
0
Helped
128747
Points
887
The water valves are clogged with grit empty machine turn off the cold water tap leave it for 3 hours check drum for water if no water in your drum do the same to your hot water the 1 that leeks water into your drum is faulty replace the faulty valve
LG washing machine leaks when filling
You just need to find where from?
Back of the soap dispenser.
Water Level Sensor.
Hoses under the drum.
Drain Pump.
Drain Hose.
Door Gasket on a Front Loader.
Full 'make model top load / front load' is useful in these questions
https://www.google.com/search?q=LG+washing+machine+leaks+when+filling
Our LG Tromm front load washer\ after washing a load water seems to be getting back into the washer drum. How is this water getting into the washer drum when the machine is shut off.
Supply lines could be leaking. Also if your drain hose is not properly placed, the water could be coming back into the tub from there. Good luck to you.
Water leak from top drum area of washer
the top ring has small drain holes if blocked the water overflows the ring instaed of going into the bowl also if the machine is not level this can cause water to splash down the outside of the bowl
2answers
LG front load washer is leaking underneath the front left corner, the display code is FE.
Why don't you simply find out what the FE code is alluding to? Go to web site or do a google search and then you can check for the issue further.
How to replace the Bearing Ball on A front load LG Washer? The Bearing Ball on My Front Load LG Washer is Leaking Water and also the tank makes a loud noise while its running. I would like to know how to...
main drum bearing is pressed into the rear outer drum 1/2. you will need to replace that part. hopefully, the motor isn't damaged by the leaking water.
My LG front load washer is leaking during the rinse cycle. I cleaned the filter and it is still leaking. What should I do?
Leakage can be a few things..Check the door boot seal for any small rips, next the fill hoses are the watertight, next drain hose , now under the machine is the pump ok, Last assuming all hoses are ok has the drum a hole in it...good luck
Sometimes there will be grease streaks on the clothes after wash.
the main bearing and seals on the drum side are faulty. this should be under warrenty
Lg tromm front loading washing machine has
Yes the system is cloghed. Pull the detergent drawer out and clean the drawers housing. try using some bleach. It allways helps.
BE ADVICED: after using bleach run quick wash cycle on without any load, it's just to get rid of all bleech remains and not to damage your clothes
Update me about your progress
LG Top Load Washer
this could be a drain hose loose or broken if the leak only occurs during rinse. If it leaks all the time, could be a broken outer drum or worn tub seal.
Hold inner drum and turn bothways. If it turns bothways, you have a bad bearing, and hence, a bad tub seal. If it turns in one direction only, bearing's good; but tub seal could still be bad.
LG/ westinghouse lifestyle font loader
what you will need to do is wright down the model number and go to ebay and put in bearings for a lg then put your model number in and it will come up with very cheap bearings thats where i get all my stock from. good luck £4.50p very cheap
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
