Question about Nordic Track Nordictrack Commercial 1300 Elliptical Power Cord For Model Number
Incline is stuck in the up position - Nordic Track Nordictrack Commercial 1300 Elliptical Power Cord For Model Number
    Top Expert:
  • Nordic Track Master
  • 12,223 Answers
LUBE the elevation motor: rack+pinion and the motor +try to adjust the POT see the picture+ diagram
However RUN the software calibration for diagnostic, troubleshooting, and fix it.
God bless you
Incline is stuck in the up position - 9_30_2012_1_41_46_pm.jpg9_30_2012_1_42_27_pm.jpg
Posted on Sep 30, 2012
SOURCE:
My Nordictrack treadmill model T7si is stuck on the 10 incline position. How do I fix it?
Check that the incline plus switch is not jammed or likely there is a defect in the panel circuit causing plus incline to be repeated. This needs to be trouble-shooted by removing and testing the panel circuit.
Oct 07, 2014 | Nordic Track Exercise & Fitness
Incline stuck treadmill
Run the software calibration for easy diagnostic and fix it. Lube the incline mechanism. Go to Hood cover motor and follow the steps or read your owner manual.
God bless you
Oct 15, 2013 | Icon Epic T60 Treadmill
My treadmill is stuck in incline
please RUN the software calibration for easy diagnose, troubleshooting, and fix it.
see the diagram attached, for troubleshooting too.see the b.diagram
Happy New Year.God bless you
Dec 31, 2012 | Treadmill Doctor Encore 1500 Treadmill...
Treadmill power incline stuck in upper postion after power outage
RUN inmediately the software calibration for diagnose, troubleshooting and fix it easy.
God bless you
Jul 11, 2012 | Proform Exercise & Fitness
My Tunturi j800 is stuck in the incline position. Other than that, it works great! How can I get it down? The screen reads that it's at 0% incline.
RUN THE SOFTWARE CALIBRATION FOR DIAGNOSE, TROUBLESHOOTING AND FIX IT.
2) you can lube the gear, shaft+ adjust the potentiometer+see the relais contact are clean it.
sincerely. God bless you
May 02, 2012 | Tunturi Exercise & Fitness
Epic treadmill t60 is stuck in max incline how do
Usually when stuck at the max up position it indicates that you may need a new incline motor. It is not the sensor. I have been repairing treadmills for 15 years and incline sensors seldom if ever go bad. If can isolate the incline motor using a 110 volt power cord, this may un-jam the motor and get it back down to 0%.
I use www.treadmillpartszone.com for parts.
Jul 25, 2010 | Icon Epic T60 Treadmill
Proform 2500 treadmill stuck in incline position
Under the motor shroud their is a instruction mini manual it will have a how to calibrate the incline motor, if that does not fix it then you may have to manually adjust the incline motor and sometimes it will take awhile to realign . If that does not work replacing the motor maybe the only option
May 02, 2010 | Exercise & Fitness
My treadmill is stuck at the highest incline and will not decline
Although it is fairly rare the incline motor can jam up into the highest position and get stuck there. To fix this take off the plastic hood that covers the incline motor and depending on the motor you should be able to wind it with your hand out of the highest position. When it is out of the highest position run the calibration as described in the owner's manual and it should go all the way up and all the way down. If it is not this type of motor that can be wound by hand then the first and last thing to do is to try calibration of the incline as described in your manual. If this does not work then a new incline motor is needed.
Dec 31, 2009 | Proform Quick Burn Pro Treadmill with 12...
My health rider treadmill s300se is stuck in the highest incline position. How do i get it level again?
Try putting the key in while holding the down incline button in. This resets the height mechanism. Repeat with the up incline button.
Worked for me.
Aug 11, 2009 | HEALTHRIDER S300SE TREADMILL Drive Motor
Nordic Track Nordictrack Commercial 1300 Elliptical Power Cord For Model Number Logo
272 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Treadmill Repairs...
Android Man
Android Man
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
