I need a manual for the power washer
SOURCE: Campbell hausfield power washer Model #pw175500le
Hi
First priming hte engine(put some gas in the plug hole)and start the engine for few times until the engine runs constantly.If not there is a fuel delivery problem.Check the air and fuel filters,the fuel line,the muffler and screen inside.Disassembly the carb,check and very carefully clean it with compresed air.
best regards savumihai71
SOURCE: Type of oil for pressure washer pump.
any anti foaming oil ,you can use multi grade but it goes milky with minute air bubbles and gives the appearance of getting water in.most manufacturers recommend anti-foaming oil
SOURCE: Hausfield Campbell pressure washer 2300 psi .Water
hi try statring the machine with no hose on, if ok add the hose to the machine without the gun and lance. then try the gun on its own WITHOUT THE NOZZEL in the lance. just elimate things regards
SOURCE: Campbell Hausfield Pressure washer model
Most likely, the housing has split and seal is not being made. There is a chance that the hose is leaking where the fitting is crimped on (my experience, but different pressure washer). Are you able to see a leak when turned off but garden hose is connected and turned on?
Is it possible that water was still in the hose / gun and froze while it was in storage?
