You need to adjust the viscosity. On your front display, on the right hand side, there is a large ice cream cone. Press the center of that ice cream cone. It'll ask you to enter a code. Using your up and down arrows, enter the code 5231 pressing the SEL button after each number. After hitting SEL for the last number, it will take you to a menu. Scroll down to Viscosity Settings. Hit SEL and then choose left or right. The top number is the current setting. If your only option is exit then press your up arrow to increase the viscosity by (0.1). Then hit SEL. Same procedure for the other side. If its still too soft, repeat the procedure. If your options are change and exit, you will have to scroll up to change and then hit SEL before you can change the setting.
www.softserveparts.com
