Question about Frigidaire Affinity ATF7000E Front Load Washer
Reverse door swing
I would like to change the door swing from left to right hand
  • Official Brand Answer
  • 4,342 Answers
Hi halej308 - Unfortunately Frigidaire front load washer doors cannot be reverse.
Posted on Oct 02, 2012
2 Suggested Answers
SOURCE:
  • 249 Answers
SOURCE: can i change the door swing?
no you can not. sorry
Posted on Nov 25, 2007
Can I easily change the door from a left swing to a right swing? do I need to buy new hardware?
Amy,
You should be able to reverse the door without much problem. You should not have to purchase any hardware. One way you can tell if you can reverse the doors is to look on the opposite side and see if there are some plastic buttons that cover up the holes where you would switch them. Hope this helps!
Apr 16, 2015 | Refrigerators
How to change doors from right to left on Whirlpool Duet
Duet dryer doors cannot be reversed for the swing. They wil only open one way. Depending on your model of washer the newers ones will allow you to reverse the door swing without a kit. The older units require a kit to reverse the washer door.
Apr 22, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
I always get confused as to the door swing direction and I need to replace one of the handle sets. Before I order I need know if it is a right or left hand door. Can you help?
Yes, Here's how. It's all about the hinges. Facing the door from the outside, if the hinges are on the left, and the door swings to the inside, it is a left hand opening door. If it swings in with the hinges on the right, it would be a right hand opening door.
Best regards, --W/D--
Jan 28, 2011 | Garden
Is it possible to reverse door swing on dryer? My daughter has a new Elite front load dryer that swings from left.
REVERSING DOOR SWING
Your dryer is designed so the door swing may be reversed at any time without additional parts. Conversion is accomplished by transferring hinges to the opposite side of the cabinet.
To change the direction of the door opening:
1. Open the dryer door. Remove the four hinge hole plugs from the left side of the door opening. Place nearby for future installation. NOTE: You may need a plastic knife to help pull out the plugs. Be careful not to scratch the paint.
2. Remove the four screws that secure the door hinges to the dryer front panel (see below). NOTE: Remove one screw from each of the two hinges first. Hold the door firmly before removing the last two screws.
3. Rotate the door 180° and reinstall the door hinges to the dryer front panel with the four screws.
4. Install the four hinge hole plugs in the open screw holes on the right side of the door opening.
Hope this helped Tim
Dec 01, 2010 | Kenmore Elite HE4 Electric Dryer
How to reverse door on kelvinator fridge?
Im unable to look up htat particular model number for you, looks like my FRT18, which is made by the electrolux company, in which case, YES you can easily switch the door swing form one side to the ohter, whats on the left goes to teh righ and right to the left, not a problem
Jan 11, 2009 | Refrigerators
Reverse door
In my experince all refrigerator doors can be converted from right to left opening. Look carefully how the doors are hinged and look for the same arrangements on the other side of the refrigerator. They may have plastic blanks which can be removed with a screwdiver, but they will be there. Turn off the fridge while working on it. And make arrangements for your frozen food if necessary.
Ray
Nov 07, 2008 | Ovens
Washing machine doors
Electrolux has a reversible door for both front load washer and dryer. Just found that out at HHGregg because we need to put our washer to the right of the dryer, and none of the other makes will allow the washer door swing to be switched.
Apr 11, 2008 | Kenmore Elite 45986 Front Load Washer
Frigidaire Affinity ATF7000E Front Load Washer Logo
329 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
