SOURCE: kenmore sewing machine manual
Type this in as you see it and don't worry about the word relics because it is just a name to get onto the page you want.
kenmore sewing machines relics
When the page comes up click on relics,
When the site comes up click on Kenmore and find your model.
SOURCE: CE5000PRW
The solution is to return the Brother and go to Sears and get a Kenmore. Most of them are made by Janome. Janome is a very good brand for both reliability and good sewing results. Flawless stitches, no jams.
We have a top of the line Kenmore and a cheapie Kenmore and both are excellent machines. Our daughter has a high end Kenmore that we got for her and she loves it.
SOURCE: Problems with lower thread tension
Did you bend the throat plate? I have done that and it was a nightmare. I took it off and gently hit it from the backside with a towel over it to bend it back the way it was. It worked fine.
SOURCE: I am sewing on demim.
The manual can be downloaded for free from Singer's web site...
Are you seeing loops of the upper thread on the bottom side? If so, then the bobbin tension is too tight, or the upper tension is too loose. The threaded shaft on the upper tension might have stripped, leaving you with no adjustability.
SOURCE: Am looking for the instruction manual for the
A manual for your
Janome 23X available, with bonus,
.....HERE
A manual for your Janome 23X available, with bonus, .....HERE
