Question about Nikon D60 Digital Camera
Nikon d60 error shutter count - Nikon D60 Digital Camera
SOURCE:
Gurudristi
  • 98 Answers
SOURCE: Shutter speed and apertue not working for Nikon D60 Digital SLR
What about other modes?
Can your camera still take photographs?
You can Try the following;
Remove the batteries , as also remove the memory card. wait for about 5 minutes. Then install the only the fully charged batteries and restart the camera. Try to use the shutter or Aperture mode, hopefully, you turn it on it and should come back to life.
If not, then it best to show to the nearest Nikon service center..
please do rate this solution and thankss for using FixYa!
Posted on Mar 08, 2009
SOURCE: Nikon d60 shutter release error
press shuter release button again
Posted on Aug 11, 2009
Ranglo
  • 1194 Answers
SOURCE: My Nikon D60 "Error. press shutter release button
Hi
The error is with the shutter release button and the unit has to be taken apart....Get it repaired by Nikon it is a common problem with these units.
Thanks for using FixYa
Have a Nice Day
Posted on Jan 25, 2011
SOURCE: my nikon d60 suddenly showed the message,error
Hi, to solve need to replace : sq base plate unit. Greethings
Posted on Feb 19, 2011
  • 269 Answers
SOURCE: can't use my D60 Nikon
This is an indication of a shutter issue. Contact Nikon for support.
Posted on Mar 01, 2011
*Error. Press shutter release button again. Nikon-D60
Your camera error is mostly like motor (aperture control unit) failing cause 90%, or 10% would be actually shutter unit defective.
Oct 02, 2014 | Nikon D60 Digital Camera
Hi
Have a Nice Day
Jan 25, 2011 | Nikon D60 Digital Camera
Error in display
Press the shutter release again. Take out the battery and put it back in a while (1-2 min). Reset the camera with the reset button.
If this doesn't work, take it to the Nikon repair.
May 30, 2010 | Nikon D60 Digital Camera
Nikon D60 "Press shutter release button again". Camera "stuck" and not working.
Remove the battery and let the camera sit for a few minutes. Reinsert the battery and turn the camera on. If the error persists, then consult with a Nikon-authorized service representative.
Jan 15, 2010 | Nikon D60 Digital Camera
Nikon d60 - error. turn camera off and on again.
Locate the button behind the shutter release button with the green dot next to it. Locate the button at the back lower hand side of the D60 with the green dot next to it. Press both buttons at the same time.........This resets the D60 to its original settings and should resolve the problem.....
Dec 14, 2009 | Nikon D60 Digital Camera
Error Message
Try to take off the battery and reset the camera. You can also try to remove the lens and check the mirror opening..see if there is some thing stuck there. You can try to click the shutter while the lens is removed. If this procedure didn't work I suggest calling Nikon for further repairs.
Sep 25, 2009 | Nikon D60 Digital Camera with 18-55mm lens
Jun 22, 2009 | Nikon D40x Digital Camera
Mar 08, 2009 | Nikon D60 Digital Camera with 18-55mm +...
Nikon D60 Digital Camera Logo
46 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Nikon Camera Expert? Answer questions, earn points and help others
