I have a ouku 7 inch dvd player when evere i turn on the truck the screem turns blue and it has a mute picture that binks on the left side i dont know wht it is can you help me
Sorry I did not use the video out RCA cables. My audio RCA cables worked fine... I ran them to my JBL amplifier through a conversion adapter. I did not run it direct to the amp.. I used Metra TYTO-01 03-08 Toyota Vehicles Harness for JBL SYS (Ebay item 160560648718) and it worked great.
Here is the wiring color coding that I found online:
Code on stereo for steering wheel is 0000
2011 Toyota Camry Car Audio Installation Diagram
F6 Pins:
1.Light Green (LG) Front Right (FR) plus (+) speakers source
2.Pink (P) Front Left (FL) plus (+) speakers
3.Grey (GR) Accessory power [switched on with the ignition switch] +12v
4.Light Blue with Yellow Stripe (L-Y) always +12v [radio memory]
5.Light Blue (L) Front Right (FR) minus (-) speakers return
6.Violet (V) Front Left (FR) minus (-) speakers return
7.Brown (BR) Ground (GND) radio ground
8.Orange (O) Antenna Amplifier (ANT) power source
9. No Connection
10.Green (G) Night Lighting [+12 when the taillights are turned on]
F7 Pins:
1.Red (R) Rear Right (RR) plus (+) speakers source
2.Black (B) Rear Left (RL) plus (+) speakers source
3.White (W) Rear Right (RR) minus (-) speakers return
4.No Connection
5.White Black (W-B) Lighting Intensity [Pull down circuit, voltage level drops {Bright Dash Lights}or raises {dim Dash Lights} Caution with this one, DO NOT CONNECT DIRECTLY TO +12 VOLTS, you will mess up your instrument panel cluster.
6.Yellow (Y) Rear Left (RL) minus (-) speakers return
F8 Pins:
1.No Connection
2.No Connection
3.Violet (V) Speed Pulse Connection (SPD) [Pulses from the speed sensors applied here. This is for the automatic sound level system. The volume raises when the speed is above a specified level, if enabled.]
4.No Connection
5.No Connection
6.Pink (P) Steering Wheel (Switch) Ground (SWG)[common]
7.Orange (O) Steering Wheel (Switch Group) one (SW1) [source for Seek+, Seek-, Volume+, & Volume-]
8.Yellow (Y) Steering Wheel (Switch Group) two (SW2) [source for Mode, (if equipped On Hook, Off Hook & Voice)
9.No Connection
10.No Connection
11.No Connection
12.No Connection
13.No Connection
14.No Connection
15.Orange (O) Auxiliary Right Input (ARI)
16.Brown (BR ) Auxiliary Shield Ground (ASGN)
17.Red (R) Auxiliary Left Input (ALI)
18.No Connection
19.Green (G) Auxiliary Input [Sense](AUXI)
20.No Connection
Car Radio Battery Constant 12V+ Wire: Blue/Yellow
Car Radio Accessory Switched 12V+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: N/A
Car Radio Dimmer Wire: N/A
Car Radio Antenna Trigger Wire: N/A
Car Radio Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Tweeter Size: 3 1/2? Tweeters
Car Audio Front Tweeter Depth: 2?
Car Audio Front Tweeter Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Blue
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Salvatore, I have been piling my hair out!! How are ya? I have the same problem in my 2004 Buick Lesabre Custom 3.8. I had been slowing installing (over weeks - drove around with an open dash). When I started having battery problems, I had just connected the bus wire (pink?) from the Ouku to the harness. Also, things started acting weird such as the right window worked intermittently? Also, I have a two modules I haven't hooked up yet (axxcess ASWC steering control and a GMRC-04 chime retention).I could not get the Ouku to read my steering controls. So those are not hooked up to the bus wire. That's next. I am going to disconnect the bus wire and see what happens. 'bus wire' or "data line" pertains to the computer and it's signals. Bus wire = 5V - don't hook it up to 12V. Lakewood Ohio David. If I am wrong somebody jump in and help!!
Get a multimeter and test the white connector to the unit under your driver seat. The red wire is power and the black is ground. If you have power there then check the unit for power. Remove the DVD player and check the individual element pins for power. On my unit the second terminal from the right is power and should measure 0.4V. If you have power there too, then it is probably your ribbon cable broken in the hindge or the DVD player itself may be defective. You can plug in a 12V source and check the DVD player outside the car to see if your probably is there.
The RED from the clarion wire must be hooked up to a switched power source ... that was wired to your old radio, then press the reset switch, and it should then turn on.
your red ignition wire is not getting 12 volts. that is why the cd player will not turn on. to test your voltage either buy a voltage tester or take it some where to have them hook it up and test it
