No serviced by pool technician. But you can look in your breaker box for a popped breaker, it should be 20 amp and be positioned in the middle instead of on or off position. Kirk
How long from the last working of that pump?
Was the Pump stored? unused?
Disassembly and try to make turns the shaft and see if it is Blocked.maybe the bearings are with water and it is rusted.
If the bearings are rusted, the mechanic seal is damaged,you need to change it and the bearings.
Hi, If you haven't already figured out how to change the seals on your Jacuzzi Magnum Force pump, I can help by supplying a diagram. Here is the parts explosion for that pump. Start by removing the case/basket assembly, then the diffuser to get to the impeller. Loosen the impeller to get to the seal plate. When going to the trouble of changing the shaft seals one should change all the hosing seals at the same time because its a lot of work.
This is not possible as it completely depends on the amount of total dynamic head the pump is connected to as well as the voltage level that is being applied.
The number one problem is air leaks.......check all connections to see that they are tight, and rubber seals. The intake side would give you trouble with air leaks. If you dont find any leaks then I would pull the pump cover and check the impellor. Pool stores have parts and lots of knowledge.
