Question about Hotpoint 24 in. FDW60 Free-standing Dishwasher
Dishwasher error codes please help
I have a hotpoint dishwasher fdw60 on the intense wash cycle it first pumps out as normal then fills with water then about 10-20 seconds later it will empty and have 2 flashing lights(fast and eco) anybody got any solutions for this as i dont have the service manual. thanks
Ive got the hotpoint fdw60 with the fast and delicate light flashing can any one help please
Posted on Sep 25, 2010
I too had this problen today. Printed off a manual from the Hotpoint website. Very helpful troubleshoot section. Anyway, flashing eco and fast lights and beeping sound indicates 'water feed pipe blocked' You need to check the water inlet connections on your tap.However, when we pulled it out we noticed the blue water inlet pipe was slightly kinked. Straightened this out and hey presto! It works fine again. How this happens when its worked ok for 18 months will never know but still. Try it! hope this was helpful...shewoo
Posted on Jul 21, 2007
Had this error myself , pulled the pump off underneath , cleaned it all out , struggled for 20 mins getting the hose connected again and hey presto , more fault codes when i started it up . . pump works ok but now its flashing eco & prewash, when i suss that out I'll let you know
Posted on Jul 08, 2007
Sezndave, just wondering if you have fixed your problem? I also have the 'Eco' and 'fast' lights flashing.
Posted on Jun 05, 2007
Electrolux wt60e error code E2
what is this plobelm how to fix it
Posted on Nov 20, 2009
I had a similar problem with my Dishwasher, firsty your going to make a mess,, take apart the pump and completely clean it out, blow into it until the little wheel inside spins,, making sure everything is out, check hoses,, etc. After putting it back together, try again, if once again it does the same thing, try the rest button, and attempt again. My problem was the same, until we found a pumkin seed in the drain pump!!!!! GOOD LUCK
Posted on Aug 04, 2007
Eco and prewash flashing means the filter needs cleaning it may have large food particles trapped within it.
Posted on Sep 03, 2007
SOURCE:
Won't wash
If this happens within the first. 9 secs after filling it means you have a hearing fault
Mar 23, 2014 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint fdw60 4th and 5th lights flashing - water wont drain away - any advice please??
That is a trouble code from the dishwasher indicating the computer ran into an unexpected problem.
This link has a pretty technical discussion of your exact problem: http://www.ukwhitegoods.co.uk/forumsphpbb3/dishwasher-forum/hotpoint-fdw60-error-codes-fast-eco-t23513.html
Your problem is a "drain time out error", which means the dishwasher waited for the water to pump out and it never happened (sounds right!).
There are a few things you can check, but unless you're very handy you will probably need a professional:
1) Is the drain line from the dishwasher to the drain plugged by anything? It could be clogged with debris that's been washed off your dishes over the years.
2) Is the drain inside your dishwasher plugged? You'll have to scoop out the water inside to see.
If neither of those, it sounds like either the onboard computer has failed and needs to be replaced, or the pump is plugged or wrecked. In either case, paying for the repairman's time will probably be more expensive than the parts themselves.
Dec 06, 2013 | Dishwashers
After drying there is water in filter trap is this normal
IF THE WATER IN PORTABLE DISHWASHER AT THE BOTTOM IS MORE THAN THE DRAIN HOSE FULL OF WATER THEN ASK WARRANTY PEOPLE. WHEN PUMPING WATER UP IT CAN ONLY PUMP SO MUCH WATER OUT OF HOSE BEFORE THE WATER DRAINS BACK INTO DISHWASHER.-- HOPE THIS HELPS
Mar 08, 2010 | Hotpoint 24 in. FDW60 Free-standing...
Eco and fast wash lights flashing together and
this does mean draining cycle has timed out due to either blockage or faulty pump...
Dec 21, 2009 | Dishwashers
When I switch on my dishwasher setting it at normal wash cycle it appears to start as normal then after few seconds goes onto to Eco 45 c wash - the light flashes but nothing happens i.e. no water comes...
you may want to check and clear the pump
you have something slowing your drain
but for giggles make sure your float valve is free to go up and down like it should
all dishwashers attempt to drain first
so you have a conflict between the float position and the pump sensor
Oct 08, 2009 | Hotpoint 24 in. FDW60 Free-standing...
FDW60 has standing water in the bottom and will not fill up
You most likely have a stubborn clog in your kitchen drain. Try filling the sinks with warm soapy water and then letting the water drain while also turning on your garbage disposal. Sometimes the extra water pressure will help push the clog through.
Jun 16, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint FDW60 flashing eco light
if the eco light is flashing, this indicates that saftey float switch has activated in the base of the dishwasher usually caused by a leak, a polystyrene float activates a microswitch which cuts of the water inlet supply
Mar 28, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint 24 in. FDW60 Free-standing Dishwasher Logo
5,389 people viewed this question
Top Hotpoint Dishwashers Experts
Archie Ferrarini
Archie Ferrarini
Marvin
Marvin
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
