The retractable zoom on my camera is in from one side and out from the other after dropping from the bed onto concrete. It goes on but the lcd doesnt come on in. it beeps for about 5 seconds and then shuts off automatically. I feel if the retractable lens is somehow put back into its grooves it should work just fine. Can somebody please help me. I just bought this yeturday. Please help
I have almost same problem - electronic unit looks like it works but the lens unit is stuck somehow from one side. Don't know how it will be fixed or is there a way to fix it?I have almost same problem - electronic unit looks like it works but the lens unit is stuck somehow from one side. Don't know how it will be fixed or is there a way to fix it?
You can't post conmments that contain an email address.
According to Sony, storing the camera lens-down in a warm area for an
extended period (a week) can help re-lubricate the retractor drive in
cases like this.
This camera seems to have a predisposition to
lens retraction problems. Try some gentle nudging, Even a small piece
of debris can jam the mechanism, so it might just need a little push or
pull.
The focus mechanism is jammed inside the lens. The lens will not retract if any of the slide rings inside the lens are out of alignment.
Read my tips page on my profile under "the only way I know how" for focus, zoom error.
If you can't free it from the out side then you have to open it up and reset it.
my email is on my tips page if I can be of any more help
The dust fibers from the case might have gotten into the cracks of the lens causing it to jam. So everytime it retracts, it jams. That's what i'm guessing. My old camera got jammed from sand grains on the beach.
- Take a thin strip of paper, and insert it in the cracks of the lens and circle around the lens and find any dust or anything. The paper slip should come out a bit dirty if that's the issue.
- Gently nudge the lens around, until you hear a click. The lens might have jerked into another position from the inside.
worked on allot of fuji's. first detease, a gear is slipping in the lens retract assembly due to a crack or wear or jam
2nd guest .. zoom errors means its really stuck tight
the gears can be ordered and replaced and one more possibility is that the motor that drives the gear is bad Also if dropped or zoom lens jammed hard... lens assembly needs total realignment or replacing..
1>>u may have dropped the camera in some place. 2>>the camera POWER ON switch must have got pressed while the camera was inside pouch. if this has happened, the lens system gets jammed and so lens wont retract. for this problem it costs nearly 1800rupees in indian service center.
If the lens is jammed in the out position you can try holding the camera firmly and tapping/hitting it against your hand with the camera on. The lens should then retract. If this doesn't work or if you are afraid of dropping it (do it on your bed, that way it doesn't hit the floor if you _do_ drop it), you can drop it on a wood/firm surface from an inch or so up and it should retract the lens. This solution ONLY WORKS IF THE LENS IS JAMMED.
Usually down to the lens block assy being faulty.Is the lens retracting and opening properly?.It usually turns out to be worn gears in the lens drive assy or the result of a fall.Either way will be expensive repair!My advise is check and see whether camera is covered by insurance for accidental knocks.,
this is a protection mechanism against further damage when the zoom/lens mechanism is obstructed. It's a very delicate mechanism, and it's not easy or cheap to fix. The gears probably got misaligned or broken when you dropped the camera. You should get a repair estimate, and only if you decide you'd rather trash it try opening it up again.
Good luck
