Key lock is set on my soniq plasma tv and i havent got the remote control for it
My Soniq tv key Loc
Anlockk not rimot how dis
Unfortunately the key lock cannot be deactivated without a remote, for it will defeat the purpose of key-locking. You can order a replacement remote, you need to have the exact information of your TV's model/version ( the barcode on the back of the TV starts in REVxxxx).
SOURCE: need universal remote control code for maxent 42" plasma tv?
I hope that you have gotten this resolved, but if not, or if you have any other questions, here are the codes and some simple steps to run through.
1. Hold down the clear TV button until all lights light up at the top of the remote
2. Punch in a 3 digit code (provided below)
3. Press the # (POUND) button
4. Try powering the tv on/off, and the volume. If one or more of these functions do not work, start over from step 1 with a different code
246
730
746
Becki Barned
DISH Network Customer Service
SOURCE: need to key unlock my soniq 106cm tv
want to unlock the chanal,s on my soniq t.v. d.v.d combo
SOURCE: virgin remote control code for volume on my 50" samsung plasma tv
To set up the volume control on your Telewest remote control, to be able to change the TV volume, please follow the instructions below.
1. Using the table below find your make of TV and the code which matches it.
2. Press and hold down Volume + and mute on your remote control at the same time for at least three seconds, until the green light in the top right-hand corner of your remote control flashes twice.
3. Release the buttons and enter the first four digit code from the table below. (You must do this within ten seconds).
4. As you enter the first three digits the green light on your remote control will give a short blink.
5. As you enter the fourth digit, the green light will flash twice to confirm that the volume is set.
If setting the volume is not successful, please repeat the above steps with the second or third codes from the table below.
Samsung 0065, 0584, 0037
SOURCE: cant set a universal remote
I expect the one for all remote you have bought will probably work the TV. Follow the instructions to teach the remote which TV you have by turning the TV on and pressing the button combination on the remote until the set turns off.
Hope you find the right one.
SOURCE: HD4208T111-PDP 42in plasma TV's remote control
HI here you go it is the best
http://www.partstore.com/
please feel free to rate my help
I can't get my remote to work on my Soniq TV ?
i locked my soniq tv by accident an got no remote
