The computer after clicking on shut down, it turns off then reboots again.
SOURCE: my computer keeps rebooting
Constant rebooting of a computer can be cause by alot of reason the most common for this is due to oevrheating, to check if this is a overheating problem try to open the case of the tower and put a electric fan in front of the tower to coll it down then power ON thecomputer and if it booted up fine with a electric fan blowing on the tower we're sure that you need to add some colling device on the computer tower, But if still do the same thing the problem here is the power supply unit it needs a replacement already....
SOURCE: computer wont turn off
There is a BIOS update available that may fix the problem. This page is for Wins XP
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&lang=en&product=431078
SOURCE: went on vacation wife turn
Hello there
I suggest you have a look at my tip ralated to this matter it is entitled My Computer is not turning on!!! Is it dead!!! No POST!!!
It will certainly keep you informed and you may learn from it for future reference.
Thanking you
damnor01
SOURCE: We have a Compaq Presario PC and we are having a
When computer is booting up, tap your function key F8 then try Last Known Good Configuration (your most recent settings that worked) or Safe Mode. If still doesn't work, you have format your computer. But before to format your computer don't forget to save or back up your data or documents. Good Day
During the boot process, a blue bar with www.dell.com appears at the top of the screen.
If you do not press in time, let the computer finish starting, and then restart the computer again.
NOTICE: If you do not want to proceed with PC Restore, click Reboot in the following step.
The restore process takes approximately 6-10 minutes to complete.
The computer restarts. Because the computer is
restored to its original operating state, the screens that appear, such
as the End User License Agreement, are the same ones that appeared the
first time the computer was turned on.
The System Restore screen appears and the computer restarts.
After the computer restarts, click OK.
Thanks and have a good one.
Oliver
