Refrigerators Logo
Aeraci Los Fresnos Posted on Sep 28, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Samsung refrigerator side by side model RS2534BB showing error code 0. What does that mean and how do I fix it?
Flashing code "0" on screen.
Anonymous
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 49 Answers
  • Posted on Sep 28, 2012
Anonymous
Expert
Level 2:
New Friend:
Cheetah:
Answers
49
Questions
Helped
8346
Points
155
Have you read your book that came with your refrigerator if you don't have one go online with your make and model number and look up Samsung refrigerator then after you fine it print it up
4 Related Answers
Anonymous
  • 1314 Answers
  • Posted on Feb 16, 2008
SOURCE: how to set cold setting on samsung side by side refrigerator modle RS2534bb
does it have the electronic display on the door if it does pop me an email at [email protected]
Anonymous
  • 3 Answers
  • Posted on Mar 01, 2010
SOURCE: error codes for Samsung Fridge
does anyone know what error code 3 is? Have the same problem, wont cool on fridge side freezer side is fine...
Anonymous
  • Posted on Apr 05, 2010
SOURCE: Miele Refrigerator model KF 1901 shows an error
I emailed Miele and this is what they reply:
Thank you for your interest in Miele products. That message is a ice fault. If the ice has stopped production, please turn the toggle switch off under the electronic touch panel. To find this please reference the owners manual on pages 7 and 9. I have included the owners manual in case yours is missing. If your machine still produces ice fine just shake the cubes around making sure none are built up along the back wall of the ice drawer. If this continues please contact our service department. Please reference incident number 2698767 should you need to call in.
For more detailed information, please visit our web site at www.miele.com or to speak with one of our representative call 800-999-1360."
Haven't tried yet, but will post again if it didn't work, otherwise should be the answer
Anonymous
  • Posted on Nov 20, 2010
SOURCE: GE PFSS6PKW display shows "88" on freezer side and
I am having the same problem after the power was turned off and then reconnected. Have you had any luck finding the source of the problem?
My Samsung fridge is flashing 33 E, 26 E and 8 E. I've tried holding down the top left and right buttons to reset; however, nothing happens. How can I fix this?
https://removeandreplace.com/2015/08/10/samsung-refrigerator-error-codes/
A power outage will make your Samsung fridge show the errors 1E and or SE. If this is the case, simply press the power save and lighting buttons for 10 seconds and the error will clear. OR... press the fridge and freezer buttons at the same time for 10 seconds to reset the control panel and clear the error code.Dec 10, 2016 https://removeandreplace.com/2016/12/10/samsung-refrigerator-flashing-blinking-faults-reset/
https://www.youtube.com/watch?v=4XW0fW9NjGU
2answers
Samsung refrigerator code -88 frezzer 88ref
Your search - Samsung refrigerator code -88 frezzer 88ref - did not match any documents.
Suggestions:
  • Make sure that all words are spelled correctly.
  • Try different keywords.
  • Try more general keywords.
  • Try fewer keywords.
I turned off the breaker and when I turned it back on my Samsung dishwasher, Model DMT800 is flashing error code CE. Whaat does this mean and how can this be fixed?
you will find same issue here and how they sorted problem..
(quote.., its a fault in the control panel and all he did to fix it was unplug it from the pcb board ( its the third plug starting from the left ) and it reset itself.
Samsung Model DMT800 Blinking CE
My Samsung refrigerator Model RFG297HDRS-XAA has 15-E code flashing.
Existing error codes for Samsung fridges run from 1 up to 13, in the majority of models as far as I could find out.
You might be having two error codes instead of one code
error 1 and Error 5.
Error 1 refers to 1. Ice Maker Sensor:
Ice Maker sensor connector missing, contact failure, electric wire cut, short-circuit, Ice Maker sensor failure.
Indicates an error when the temperature sensed by Ice Maker sensor is higher than 150 or lower than -58.
Error 5 refers to 5. Ice Maker Function Error:
Ice ejector and level failed three times or more.
4helpful
Flashing freezer led
a flashing display is how samsung shows error codes. try and draw a picture of which segments of the display is flashing. think of the figure 8 and then try to show which part of the 8 is being shown. that is how we can tell what error code needs fixed.
3helpful
2answers
Fridgidaire refrigerator flashing error code 4
From what I remember a flashing 4 means "damper error". Send your model number found inside or on the outside of the fresh food section, The air damper is found between the freezer and fresh food section and regulates temperature in the fresh food section by opening wide for things that warm up your fresh food section example would be opening the door and letting warm air inside . The damper then closes to keep the right temperature. If you have questions please ask, Thanks Sea Breeze
Default password of Samsung S3850
*#9998*289# : Change Alarm Buzzer Frequency *#9998*364# : Watchdog *#9998*523# : Change LCD contrast - Only with version G60RL01W *#9998*746# : SIM File Size *#9998*862# : Vocoder Reg - Normal, Earphone or carkit can be selected *#9998*786# : Run, Last UP, Last DOWN If the up Codes doesn't work, you should change *#9998* to *#0. i.e. *#9998*523# change to *#0523#. An other thing that will help is to remove your SIM card. *0001*s*f*t# : Changes serial parameters (s=?, f=0,1, t=0,1) (incomplete) *0003*?# : unknown *0003*?# : unknown
*#9998*377# : EEPROM Error Stack - Use side keys to select values. Cancel and ok *#9998*427# : Trace Watchdog *#9998*785# : RTK (Run Time Kernel) errors - if ok then phn is reset, info is put in memory error. *#9998*778# : SIM Service Table *#9998*947# : Reset On Fatal Error *#9998*872# : Diag *#9998*999# : Last/Chk *#9998*324# : Debug screens *#9998*636# : Memory status *#9998*544# : Jig detect *#9998*842# : Test ******** - Flash the screenligth during 10 seconds and vibration activated *#9998*837# : Software Version *#9998*228# : Battery status (capacity, voltage, temperature) *#9998*246# : Program status *#9998*9266# : Yann debug screen (=Debug Screens?)
*#9998*9999# : Software version
SP-unlock SGH-600 (and also SGH-Sgh-600 *2767*3855# : Full EEPROM Reset ( THIS CODE REMOVES SP-LOCK!! ) But also changes IMEI to 447967-89-400044-0. (Doing this is illegal) *2767*2878# : Custom EEEPROM Reset *These codes have been tested with version FLD_2C6 G60SB03X of Samsung SGH-600 Samsung SGH-600 Unlock Codes *#9999# : Show Software Version *#9125# : Activates the smiley when charging. *#0001# : Show Serial Parameters *#0837# : Show Software Version (instructions) *#06# : Show IMEI
3answers
Error codes for Samsung Fridge
you need to check the refrigerator defrost sensor connection thats behid the light bulb in the middle of the refrigerator section
Top Samsung Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
