Question about Leisure DWLT65 Dishwasher
My leisure dwlt65 dishwasher keeps switching its self off when going till wash
Would u not wat is wrong?
    Top Expert:
  • Leisure Master
  • 12,223 Answers
See this causes and fix it. God bless you
Touchpad and Control Panel If the buttons don't work on the control panel the entire touchpad and control panel assembly may need to be replaced. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad If the buttons don't work on the control panel, the dishwasher touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
Main Control Board The dishwasher has a main control board which regulates nearly every function in the dishwasher. If the control panel buttons don't work, and other causes have been have ruled out, the main control board might need to be replaced.
Posted on Sep 29, 2012
SOURCE:
The power button is crackling when i turn my Leisure DWLT65 dishwasher on. is it the power switch?
Hello. Here is the link to the power button for your unit. Most likely, the contacts inside the switch have worn out causing arcing--hence the crackling sound you heard. I would not use the washer until you get the switch repaired! If the internal contacts are not touching properly, heat will be generated and could cause the switch to melt, thereby creating a real safety hazard(I've seen this happen). Leisure DWLT65 On Off Power Switch I hope I helped you!
Feb 23, 2015 | Leisure Dishwashers
Not emping water
This is a generalize answer, but remove the bottom kick panel to manually rotate the pump motor. In general they can get locked up by objects. Locking up the pump.
May 26, 2014 | Leisure DWLT65 Dishwasher
Dishwasher will not start after being switched on- can you help
Here is the link to the power button for your dishwasher: http://www.amazon.co.uk/Leisure-DWLT65-Off-Power-Switch/dp/B00O470CVM. I hope this helps you!
Jan 03, 2014 | Leisure DWLT65 Dishwasher
MODEL # ZD4200DO2BB IT WOULD NOT DRAIN ON THE WASH CYCLE THE WATER AND FOAM COME OUR FROM THE FRONT WHAT CAN I DO?
Sounds like you put in the wrong soap. Dishwasher soap should not froth up. If it is all frothed up keep adding cold water manually and keep pumping till all suds gone.
Oct 15, 2010 | Dishwashers
Hoover hed6612 dishwasher wont work
We have had the same problem but have found a fix.
1. If any of the wheels have come off the top sliding basket/rack you need to make sure they are all back on for each wash ( ours are very loose! )
2. Push the top rack in FIRMLY before you wash - make sure it engages at the back.
That's it - solved it for us after months of problems.
I think that as the wheels get worn the top rack does not fully engage at the back and this is when the problem starts manifesting itself. We have some new wheels on order but they are taking ages to arrive.
Jul 08, 2009 | Maytag Dishwasher
My hedge trimmer keeps switching off
It sounds like you may have a loose wire some where that is grounding out. You might want to check all wire connections to make sure that they are tight and also check for any bare spots in the wires were they could be touching metal and grounding its self out.
Jan 06, 2009 | Electrolux Gas Hedge Trimmer
Dishwasher does not work all the time
Your dishwasher i believe has a potential start relay, it sounds like this relay is faulty and not disengaging the start winding properly. Remove the two lower panels there will be a small plastic looking switch with 3 wires and coiled with bare copper wire.
Oct 14, 2007 | Maytag PDB3600A Built-in Dishwasher
Leisure DWLT65 Dishwasher Logo
314 people viewed this question
Top Leisure Dishwashers Experts
Marvin
Marvin
Are you a Leisure Dishwasher Expert? Answer questions, earn points and help others
