Question about Yamaha RX-V473 5.1 Channel Network AV Receiver
Yamaha receiver will not connect to Airplay
This receiver has network connection with internet radio, airplay and can be remote controlled from smartphone. The receiver will not show up as an Airplay device in itunes or iphone. After a lot of trial I have found out that it appears when the receiver is newly connected to the network. Than I can stream music to it for hours. But, if I don't start Airplay when it is fresh connected to the net, it will newer show up as a device. However, I can always play internet radio and control i from the phone, so the network connection is there, but Airplay disappears of some reason.
I have the same problem, it seems the airplay connection is easily lost, it never plays for longer than an hour without itunes losing the receiver, then i have to reset the receiver so that it appears in itunes again, very annoying. I spoke to Yamaha and they are not aware of any issues but clearly there is one. A quick workaround is to bring the receiver up in a browser by typing in its IP address, go to IP Address tab and simply apply without changing anything, this causes the receiver to initialize its network function as you will see the amp resetting and it will then appear in iTunes. This doesn't work through the units setup without changing settings and then changing them back again. Hopefully this is just a glitch that will Yamaha will fix in the next firmware update, I am running 1.14 update.
Posted on Nov 20, 2012
  • 5 more comments
  • Brent Cutler Dec 04, 2012
    Update 4th December. Issue now resolved, it was my router a Dlink-DSL2780 supplied by Talk Talk, it doesntt perform streaming very well. I bough a WD MYNET600 and a seperate ADSL Modem and its now completely stable.
  • peterjohn906
    peterjohn906 Apr 10, 2013
    Seconded, when I had similar problems it was the router (I went for an Apple Airport router to solve it)
  • highstrng1
    highstrng1 Apr 12, 2013
    YEP!! THANK YOU.. it was my dlink router.. I just plugged into my airport instead. worked instantly.
  • Phil Apr 14, 2013
    I have the same issue too. I changed from my out-of-the-box Telstra router to a Belkin N router, and I still have the same issue. Doing the "apply" work around as suggested by Brent corrects the issue temporarily.
  • David O Brien Jul 09, 2013
    Has anyone had a permanent fix for this with the 1.16 firmware update? I am having similar problems....
  • Tom?? Parkan
    Tom?? Parkan Aug 24, 2013
    I have same problem with NAS Synology and Yamaha HTR-4065. After switch on receiver don't see this NAS, but internet radio working. After reconnection suddenly NAS (or my PC) is on list of Servers. I tried new firmware and nothing change.
  • Tom?? Parkan
    I have same problem with NAS Synology and Yamaha HTR-4065. If I reciever switch on internet radios working, but list of servers is empty. When I reconnect reciever (change network settings or reconnection cable), NAS and DLNA server on my computer suddenly are on the list. I tried new firmware, but nothing change. It's very uncomfortable. Anyone have solved yet?
    New Friend:
Can I stream video on AirPlay to the Yamaha rx v475?
the sound is working fine with airplay and Yamaha's app but video won't show, they are played as sound only.
Posted on Nov 18, 2013
5 Suggested Answers
SOURCE:
SOURCE: Yamaha RX-V800 Remote Control
Change the batteries
Posted on Nov 13, 2007
SOURCE: Yamaha RXV661 Receiver has Zone 2 Vol Fix error message
i have the same problem. i have a rx-v661. i goto the zone 2 settings and try to change the volume and it says VOL FIX. I cannot hear anything out of zone 2. It takes the current volume that is in zone 2, but i cannot hear anything. it has been working fine for at least a year.
Posted on Jun 27, 2009
SOURCE: Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Solved problem with Yamaha HTR-6040 AV Receiver. My daughter had inadvertently changed the program to "Direct Stereo" mode which allows sources to bypass the decoders and DSP processors so you can listen to 2-Channel PCM and Analog sources. Nothing to decode digital audio in this setting!
Posted on Aug 10, 2008
  • 948 Answers
SOURCE: I'd like to connect my HP laptop to Yamaha 663 receiver
Connect your S-video output from the computer to an empty S-video input on the receiver. Connect your speaker output from computer to analog audio input on the receiver using a 1/8" stereo connector to RCA patch cable. You may have to set your computer to output video to the S-video jack, consult your HP documentation for instructions.
Posted on Dec 29, 2008
Can connect to AirPlay but there is no sound.
you could buy a good radio for the shop
Apr 22, 2015 | Audio Players & Recorders
How do i connect by airplay
Without know what you are wanting to connect by airplay, it is difficult to provide specific instructions. But essentially, the device you want to connect to via Airplay must be "Airplay" compatible in order for it to receive a signal from your iOS/Apple product. If it is, then you'll select the Airplay icon on your Apple product, which will bring up the menu of Airplay devices in the vicinity. You'll then select the device you want to use from this Airplay menu.
Sep 29, 2014 | Audio Players & Recorders
Does the Yamaha RX-V500D receiver connect the airplay wirelessly?
It is supposed to play wireless. But you have to read the manual how to connect, because you have to setup the airplay (once per device)
Sep 06, 2014 | Yamaha Audio Players & Recorders
RCD n7 is stuck in Internet radio mode. Won't respond to remote control commands
I have the same problem. Sometimes I resolve it by unplugging it for a couple of hours. I took it to Richer sounds and they got it working again for a couple of weeks. Very dissapointed
Sep 21, 2013 | Denon RCD-N7 Network Ready Receiver with...
AirPlay won't connect to harman kardon receiver
My iPhone has a button at the bottom right-hand side of the screen (next to the volume control), that gives me the option to listen on the phone or to have it run on the Harman Kardon airplay. It automatically turned on the receiver and played the sound of the video in surround sound. It looks like a rectangle with a triangle at the bottom of it.
Mar 11, 2013 | iPhone Apps
Won't log into pandora
http://us.marantz.com/DocumentMaster/us/PressReleases/PandoraProblem-M.pdf
Dec 01, 2012 | Marantz SR5006 AV Receiver with Networking...
Yamaha RX V673 airplay problem
Disable IGMP filter on your router
Nov 13, 2012 | Yamaha RX-V673
Airplay not working
I had the same problem. You can disable IGMP filter on your router. It will fix it.
Jul 29, 2012 | Yamaha RX-V673
Airplay for ipod, mac and iPad does not work
I have the same problem. It does that When you leave the receiver on Airplay and try to reconnect to it. Force the receiver to an other mode and than dicsonnect your IOS device from the network, reconnect it and it should work...
Jul 06, 2012 | Pioneer Vsx-822-k 80wx5 6 3d Hdmi Inputs...
Yamaha RX-V473 5.1 Channel Network AV Receiver Logo
12,405 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
