Television has no power. outlet has power and cord from outlet to television has power. is there a fuse?
All telivisions has fuses inside. Some of them has one, and some has two. If your tv doesn't power on, and power chord and outlet is ok, surely the fuse inside may blown out. There may be some reason for the blowing of fuse. Fuses are used inside tvs are for protection purposes. f any overvoltage or over current taken by the system, the fuse will blow out. you must fist find out the resom for the bowing of fuse. New fuse must be put in only after that check. Otherwise you will spoil the whole circut board inside the tv irrepairable. Concat a service personnal, and let him do that. Ok.
Remember, different tvs have different power ratings. Must select proper fuse according to the ratings.
i have the same problem but i do know there are fuses that are sodered in the board. you can check those.I found one of mine to be bad.I went to The electronic place and got some , it was the 5 amp one in mine. The Tv has a diagram of where they are on the right side of the inside case.cost me 7 bucks for 5 fuses but they only sold 5 at a time...
