Runs fine but its not generating any power
SOURCE: Problem with a kipor 12 ta generator
I just guessing here but it could mean that the oil pressure is too low.
I'd check the oil level first, then look for the oil pressure switch and temporarily disconnect it.
Regards,
Carl
SOURCE: kipor generator starts ok but will not provide electricity to apppliances
first check the circuit breakers if there ok the problem is inside like over heated parts
check for a small fracture on the tubing caused from age and flexing from vibration. It is usually right where the tubing comes off the carburetor.
Hi!
We have a put together a guide here to assist you in these situations. It will guide you through testing and repairing the Generator. : https://www.generatorguru.com/need-help/
If you need any further help our Generator Engineers are happy to assist you.
Regards,The Generator Guru Team
The DC output for battery charging is from the engine alternator and is completely independent from the generator inverter.
As this is an inverter unit the typical polarization techniques for standard generators will not apply.
The ouput indicator being lit means the inverter input output should be good. This further implies a circuit disconnect state at the outlets. Try pressing the overload reset switch to make sure it is not in an odd state.
