That is normal. Its not a malfunction, that is how all chargers are. For that reason you should buy a cooling pad for your laptop which i'm sure becomes hot too, many times
run it in battery to see if fixes cursor problem
also try a different mouse see if that makes the cursor move correctly
this way you see if its the mouse or power supply
might also a touch pad problem anything that controls the cursor
Have a look around the base of the laptop for access panels, if you remove these, one of them should give you access to the fan, this fan blows air through a heatsink in order to cool the laptop down, clean all around the fan and also remove the fan to clear the gap in between the fan and the heatsink as dust builds up there very easily.
there must be some problem in battery charging.change the battery and charge it.this will mostly helpful to you.if same problem exist means.then check the charging pin in your charger and in mobile too.if so try to change the charging pin of your mobile.
check output voltage on charger label most chargers are not regulated so if it says 18 volt output it may put out 24 volts but if its putting out 51 volts it may have a short batteries will get warm but not hot replace charger
