SOURCE: volvo xc90 2004 buzzing in steering wheel, clunck noise under car
that sounds like you are low on power steering fluid ... when the level gets low then the pump starts to ingest air and that produces a buzzing sound when you turn the wheel .....i would add or change the fluid and check for leaks and mechanical loosness in the under car linkages ...you can have that checked at your next oil change .
Testimonial: "Thank you, you were right I took the car in and they said the steering fluid was low. "
SOURCE: key won't turn, steering wheel locked, brakes locked.
With the key in the ignition, tap on the key with something heavy like a pair of pliers, screwdriver etc. It will cause the pin inside the mechanism to drop, and the iginition will turn. Happened to me today, worked like a charm.
SOURCE: Steering wheel locked.. can't move key ...
The key should turn if you turn wheel as much as you can while turning key
SOURCE: hello, my steering wheel is
All you need to do is turn your steering wheel to the left all the way till it stops then put your key in while still holding the steering wheel to the left, turn the key to the on position this should release your steering wheel!
SOURCE: My 2006 Malibu steering wheel is going bad.
The power steering is electric on that car. It has a electric motor on the column, and a control module. There are several causes that could be the problem. You need to have it scanned to get a better idea of what to do. If you can give me the codes you get then I will be glad to advise you on what's best. Good Luck
